| 0006768 | ParaView | (No Category) | public | 2008-04-07 17:53 | 2016-08-12 09:57 | ||||
| Reporter | Ken Moreland | ||||||||
| Priority | low | Severity | minor | Reproducibility | have not tried | ||||
| Status | closed | Resolution | moved | ||||||
| Product Version | |||||||||
| Target Version | Someday | Fixed in Version | |||||||
| Summary | 0006768: Select any array as texture coordinates | ||||||||
| Description | Right now, you can only use an array for texture coordinates if it is assigned as the active texture coordinates in the data structure. Furthermore, there is no direct way to set the active texture coordinates. A better approach (I think) is to be able to select any array to use as the texture coordinates. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0011131) Ken Moreland (manager) 2008-04-07 17:55 |
This is not a user request (yet); it's just one of those pie-in-the-sky I-think-we-should-have-that requests. I don't know for sure if we will need this, but I'm quite sure that the current method of getting texture coordinates will not be sufficient for anyone serious about texture mapping. I figure this method should be fairly easy to implement and powerful enough to handle future use cases. |
(0037562) Kitware Robot (administrator) 2016-08-12 09:57 |
| Notes |
| Issue History | |||
| 2008-04-07 17:53 | Ken Moreland | New Issue | |
| 2008-04-07 17:53 | Ken Moreland | Status | backlog => tabled |
| 2008-04-07 17:53 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
| 2008-04-07 17:53 | Ken Moreland | Priority | normal => low |
| 2008-04-07 17:55 | Ken Moreland | Note Added: 0011131 | |
| 2008-04-10 16:11 | Utkarsh Ayachit | Relationship added | related to 0004788 |
| 2009-03-20 17:06 | Ken Moreland | Category | 3.6 => Someday |
| 2009-05-13 13:49 | Utkarsh Ayachit | Target Version | => Someday |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| 2016-08-12 09:57 | Kitware Robot | Note Added: 0037562 | |
| 2016-08-12 09:57 | Kitware Robot | Status | expired => closed |
| 2016-08-12 09:57 | Kitware Robot | Resolution | open => moved |
| Issue History |
