| 0006734 | ParaView | Bug | public | 2008-04-07 13:47 | 2010-11-16 18:39 | ||||
| Reporter | amaclean | ||||||||
| Assigned To | David Partyka | ||||||||
| Priority | normal | Severity | major | Reproducibility | always | ||||
| Status | closed | Resolution | no change required | ||||||
| Product Version | |||||||||
| Target Version | Someday | Fixed in Version | 3.8 | ||||||
| Summary | 0006734: Installation of Paraview | ||||||||
| Description | Install fails when it reaches this point because "C:\Q" is not being treated as C:/Q. See the output below: 1>-- Installing: C:/Program Files/ParaView/bin/QTASSISTANTCLIENT4.dll 1>CMake Error: Invalid escape sequence \Q 1>Syntax error in cmake code at 1>C:/Users/amaclean/Code/Kitware/build/ParaView/Applications/Client/cmake_install.cmake:82: 1>syntax error, unexpected cal_ERROR, expecting $end (4), when parsing string "C:\Qt\qt-win-opensource-src-4.3.4\bin/assistant.exe" 1>-- Installing: C:/Program Files/ParaView/bin/assistant.exe 1>-- Installing: C:/Program Files/ParaView/bin/pvTestDriver.exe 1>Project : error PRJ0019: A tool returned an error code from "Performing Post-Build Event..." | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0021393) Utkarsh Ayachit (administrator) 2010-07-14 14:18 |
Not relevant anymore. |
(0023166) David Partyka (developer) 2010-11-11 09:25 |
The Qt installation rules have gone through several changes and are now handled by the BundleUtilities cmake module. If you're still having issues please let us know. |
(0023321) Alan Scott (manager) 2010-11-16 18:39 |
I believe Dave's answer is correct. Please reopen if this is still a problem. |
| Notes |
| Issue History | |||
| 2008-04-07 13:47 | amaclean | New Issue | |
| 2008-04-15 12:53 | Berk Geveci | Status | backlog => @30@ |
| 2008-04-15 12:53 | Berk Geveci | Category | Development => 3.6 |
| 2009-02-17 14:11 | Ken Moreland | Category | 3.6 => Someday |
| 2009-05-13 13:49 | Utkarsh Ayachit | Target Version | => Someday |
| 2010-07-14 14:18 | Utkarsh Ayachit | Note Added: 0021393 | |
| 2010-07-14 14:18 | Utkarsh Ayachit | Resolution | open => won't fix |
| 2010-07-14 14:18 | Utkarsh Ayachit | Category | => Bug |
| 2010-11-11 09:23 | David Partyka | Status | @30@ => tabled |
| 2010-11-11 09:23 | David Partyka | Assigned To | => David Partyka |
| 2010-11-11 09:25 | David Partyka | Note Added: 0023166 | |
| 2010-11-11 09:25 | David Partyka | Status | tabled => @80@ |
| 2010-11-11 09:25 | David Partyka | Fixed in Version | => 3.8 |
| 2010-11-11 09:25 | David Partyka | Resolution | won't fix => no change required |
| 2010-11-16 18:39 | Alan Scott | Note Added: 0023321 | |
| 2010-11-16 18:39 | Alan Scott | Status | @80@ => closed |
| Issue History |
