| 0006480 | ParaView | (No Category) | public | 2008-02-29 11:56 | 2010-11-16 18:32 | ||||
| Reporter | Mike Jackson | ||||||||
| Assigned To | David Partyka | ||||||||
| Priority | normal | Severity | block | Reproducibility | always | ||||
| Status | closed | Resolution | no change required | ||||||
| Platform | Windows XP | OS | Windows XP | OS Version | SP2 | ||||
| Product Version | |||||||||
| Target Version | Someday | Fixed in Version | 3.8 | ||||||
| Summary | 0006480: Install Target does not work on Windows XP (VS 2003.net or VS2005) | ||||||||
| Description | Running the "Install" target from within visual studio results in a error due to the path not being correct. Somewhere the variable ${QT_BINARY_DIR} has been converted to a windows native path with messes up the generated cmake script. The following code should be used instead starting at line 552 of ParaView3/Applications/Client/CMakeLists.txt IF(WIN32) GET_FILENAME_COMPONENT( QT_ASSISTANT_PATH QT_QMAKE_EXECUTABLE} PATH) SET(QT_ASSISTANT_PATH "${QT_ASSISTANT_PATH}/assistant.exe") INSTALL(FILES "${QT_ASSISTANT_PATH}" DESTINATION ${PV_EXE_INSTALL_CM24} PERMISSIONS OWNER_WRITE OWNER_READ OWNER_EXECUTE GROUP_READ GROUP_EXECUTE WORLD_READ COMPONENT Runtime) | ||||||||
| Steps To Reproduce | Run the "install" project from within Visual Studio | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0010670) Mike Jackson (reporter) 2008-02-29 12:09 |
There was a typo in the last report. This is the corrected cmake code IF(WIN32) GET_FILENAME_COMPONENT( QT_ASSISTANT_PATH ${QT_QMAKE_EXECUTABLE} PATH) SET(QT_ASSISTANT_PATH "${QT_ASSISTANT_PATH}/assistant.exe") INSTALL(FILES "${QT_ASSISTANT_PATH}" DESTINATION ${PV_EXE_INSTALL_CM24} PERMISSIONS OWNER_WRITE OWNER_READ OWNER_EXECUTE GROUP_READ GROUP_EXECUTE WORLD_READ COMPONENT Runtime) |
(0023288) David Partyka (developer) 2010-11-16 10:17 |
We no longer use assistant for documentation so this should be a none issue. |
| Notes |
| Issue History | |||
| 2008-02-29 11:56 | Mike Jackson | New Issue | |
| 2008-02-29 12:09 | Mike Jackson | Note Added: 0010670 | |
| 2008-04-15 12:46 | Berk Geveci | Status | backlog => @30@ |
| 2008-04-15 12:46 | Berk Geveci | Category | Development => Someday |
| 2009-05-13 13:49 | Utkarsh Ayachit | Target Version | => Someday |
| 2010-11-16 10:16 | David Partyka | Assigned To | => David Partyka |
| 2010-11-16 10:16 | David Partyka | Status | @30@ => tabled |
| 2010-11-16 10:17 | David Partyka | Note Added: 0023288 | |
| 2010-11-16 10:17 | David Partyka | Status | tabled => @80@ |
| 2010-11-16 10:17 | David Partyka | Fixed in Version | => 3.8 |
| 2010-11-16 10:17 | David Partyka | Resolution | open => no change required |
| 2010-11-16 18:32 | Alan Scott | Status | @80@ => closed |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
