| 0006386 | ParaView | (No Category) | public | 2008-02-19 15:49 | 2009-05-13 13:45 | ||||
| Priority | normal | Severity | feature | Reproducibility | always | ||||
| Product Version | |||||||||
| Target Version | 3.6 | Fixed in Version | |||||||
| Summary | 0006386: Animation inspector and Animation view are redundant | ||||||||
| Description | Would it be a good idea to get rid of the redundant features between the animation inspector and the animation view? Maybe somehow tie them together as just the Animation View? | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |||||||||||
| Relationships |
| Notes | |
(0010596) Ken Moreland (manager) 2008-02-20 08:26 |
Personally, I would like to see the animation inspector removed altogether and just use the newer animation view. |
(0010718) Alan Scott (manager) 2008-03-05 21:07 |
I agree with Ken. We would have to move the "Animation Settings/ Cache Geometry" functionality to the Animation View, or preferences, etc. |
(0010733) Ken Moreland (manager) 2008-03-06 16:46 |
More agreement... If I remember, all the non-redundant GUI options are settings like Cache Geometry. Thus, they belong in the settings dialog box. It is also convenient to put them there as the Animation View is pretty full. |
(0011298) Clinton Stimpson (developer) 2008-04-14 17:23 |
I agree too. It would be nice to see 5577 fixed first, so no features are lost, when trying to animate certain types of properties. |
(0015036) Ken Moreland (manager) 2009-02-17 13:23 |
Once bug 0005768 is complete, I think enough of the functionality of Animation Inspector will be implemented in Animation View. At that point, just remove Animation Inspector. |
(0016140) Utkarsh Ayachit (administrator) 2009-04-22 12:20 |
Fixed BUG #6383. Removing Animation Inspector. It has bee replaced by Animation View. Changed tests to use the new animation view instead of the inspector. /cvsroot/ParaView3/ParaView3/Applications/Client/CMakeLists.txt,v <-- Applications/Client/CMakeLists.txt new revision: 1.204; previous revision: 1.203 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/Python/DisconnectAndSaveAnimation.py,v <-- Applications/Client/Testing/Python/DisconnectAndSaveAnimation.py new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/Python/SaveAnimationMultiView.py,v <-- Applications/Client/Testing/Python/SaveAnimationMultiView.py new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/SaveAnimationGeometry.xml,v <-- Applications/Client/Testing/XML/SaveAnimationGeometry.xml new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/TemporalInterpolator.xml,v <-- Applications/Client/Testing/XML/TemporalInterpolator.xml new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Applications/OverView/Core/MainWindow.cxx,v <-- Applications/OverView/Core/MainWindow.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Applications/OverView/Core/MainWindow.ui,v <-- Applications/OverView/Core/MainWindow.ui new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/CMakeLists.txt,v <-- Qt/Components/CMakeLists.txt new revision: 1.163; previous revision: 1.162 /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationPanel.cxx,v <-- Qt/Components/pqAnimationPanel.cxx new revision: delete; previous revision: 1.56 /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationPanel.h,v <-- Qt/Components/pqAnimationPanel.h new revision: delete; previous revision: 1.14 /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationViewWidget.cxx,v <-- Qt/Components/pqAnimationViewWidget.cxx new revision: 1.37; previous revision: 1.36 /cvsroot/ParaView3/ParaView3/Qt/Components/pqClientMainWindow.cxx,v <-- Qt/Components/pqClientMainWindow.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- Qt/Components/pqMainWindowCore.cxx new revision: 1.314; previous revision: 1.313 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.h,v <-- Qt/Components/pqMainWindowCore.h new revision: 1.103; previous revision: 1.102 /cvsroot/ParaView3/ParaView3/Qt/Components/pqCurrentTimeToolbar.cxx,v <-- Qt/Components/pqCurrentTimeToolbar.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqCurrentTimeToolbar.h,v <-- Qt/Components/pqCurrentTimeToolbar.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqAnimationPanel.ui,v <-- Qt/Components/Resources/UI/pqAnimationPanel.ui new revision: delete; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqClientMainWindow.ui,v <-- Qt/Components/Resources/UI/pqClientMainWindow.ui new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationWidget.cxx,v <-- Qt/Widgets/pqAnimationWidget.cxx new revision: 1.19; previous revision: 1.18 |
(0016208) Alan Scott (manager) 2009-04-27 21:45 |
Tested client/ remote server. |
| Notes |
| Issue History | |||
| 2008-02-19 15:49 | Alan Scott | New Issue | |
| 2008-02-20 08:26 | Ken Moreland | Note Added: 0010596 | |
| 2008-03-05 21:07 | Alan Scott | Note Added: 0010718 | |
| 2008-03-06 16:46 | Ken Moreland | Note Added: 0010733 | |
| 2008-03-07 07:53 | Berk Geveci | Status | backlog => tabled |
| 2008-03-07 07:53 | Berk Geveci | Assigned To | => Clinton Stimpson |
| 2008-04-09 18:56 | Ken Moreland | Category | => 3.4 |
| 2008-04-14 17:21 | Berk Geveci | Category | 3.4 => 3.6 |
| 2008-04-14 17:22 | Clinton Stimpson | Relationship added | related to 0005576 |
| 2008-04-14 17:22 | Clinton Stimpson | Relationship deleted | related to 0005576 |
| 2008-04-14 17:22 | Clinton Stimpson | Relationship added | related to 0005577 |
| 2008-04-14 17:23 | Clinton Stimpson | Note Added: 0011298 | |
| 2009-02-17 13:22 | Ken Moreland | Relationship added | related to 0005768 |
| 2009-02-17 13:23 | Ken Moreland | Assigned To | Clinton Stimpson => Burlen |
| 2009-02-17 13:23 | Ken Moreland | Note Added: 0015036 | |
| 2009-04-22 09:52 | Utkarsh Ayachit | Assigned To | Burlen => Utkarsh Ayachit |
| 2009-04-22 12:20 | Utkarsh Ayachit | Note Added: 0016140 | |
| 2009-04-22 12:20 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2009-04-22 12:20 | Utkarsh Ayachit | Resolution | open => fixed |
| 2009-04-27 21:45 | Alan Scott | Note Added: 0016208 | |
| 2009-04-27 21:45 | Alan Scott | Status | @80@ => closed |
| 2009-05-13 13:45 | Utkarsh Ayachit | Target Version | => 3.6 |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
