| 0006233 | ParaView | (No Category) | public | 2008-01-10 16:30 | 2011-01-13 17:00 | ||||
| Priority | low | Severity | major | Reproducibility | always | ||||
| Product Version | |||||||||
| Target Version | 3.4 | Fixed in Version | 3.4 | ||||||
| Summary | 0006233: Data that has a VERY small scale doesn't display and resize properly. | ||||||||
| Description | Note - this must be done exactly as below to see bug. Source/ Sphere/ Apply. TransformFilter. Scale X=1e-5, Y=1e-5, Z=1e-5. Apply. Hit Reset. Object never appears. Center cross gets very small. The lower left XYZ arrows get big. Hit Reset. Object never appears. Center cross goes away. Scale X=1e-4, Y=1e-4, Z=1e-4. Apply. Hit Reset. Sphere is still gone. Change eye focus to the SphereSource. Sphere is gone. Hit Reset. Sphere is visible. (Sometimes the screen goes white, and it takes a second reset.) Hit Reset. Sphere is visible. Change eye focus to the Transform. Sphere is back. This occurs with exodus files also (and I suspect, everything). I am marking it as severe (major), but not seen (low priority). | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |||||||||||
| Relationships |
| Notes | |
(0012596) ufnoise (reporter) 2008-07-01 17:55 |
This issue is affecting me too. I simulate submicron devices and I am seeing this with a 2d unstructured mesh 1e-5 by 1e-5. This is important for me since simulations structures vary from submicron 1e-8 to micron 1e-4. Thanks |
(0012605) Utkarsh Ayachit (administrator) 2008-07-03 10:35 |
The minimum limits were too large. Lowering the limits to 1e-20. /cvsroot/ParaView3/ParaView3/VTK/Rendering/vtkCamera.cxx,v <-- VTK/Rendering/vtkCamera.cxx new revision: 1.116; previous revision: 1.115 |
(0012642) Alan Scott (manager) 2008-07-07 19:05 |
Tested client/server. Works fine. |
| Notes |
| Issue History | |||
| 2008-01-10 16:30 | Alan Scott | New Issue | |
| 2008-04-10 17:26 | Ken Moreland | Relationship added | has duplicate 0006581 |
| 2008-04-15 12:03 | Berk Geveci | Assigned To | => Berk Geveci |
| 2008-04-15 12:03 | Berk Geveci | Status | backlog => tabled |
| 2008-04-15 12:03 | Berk Geveci | Category | => 3.4 |
| 2008-05-29 13:18 | Berk Geveci | Relationship added | related to 0005576 |
| 2008-06-03 11:37 | Utkarsh Ayachit | Assigned To | Berk Geveci => Utkarsh Ayachit |
| 2008-07-01 17:55 | ufnoise | Note Added: 0012596 | |
| 2008-07-03 10:35 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2008-07-03 10:35 | Utkarsh Ayachit | Resolution | open => fixed |
| 2008-07-03 10:35 | Utkarsh Ayachit | Note Added: 0012605 | |
| 2008-07-07 19:05 | Alan Scott | Status | @80@ => closed |
| 2008-07-07 19:05 | Alan Scott | Note Added: 0012642 | |
| 2009-05-13 13:58 | Utkarsh Ayachit | Target Version | => 3.4 |
| 2009-05-13 13:59 | Utkarsh Ayachit | Fixed in Version | => 3.4 |
| 2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
| 2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
