| 0006208 | ParaView | (No Category) | public | 2008-01-02 09:56 | 2009-05-13 13:59 | ||||
| Reporter | Ken Moreland | ||||||||
| Assigned To | Burlen | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Product Version | |||||||||
| Target Version | 3.4 | Fixed in Version | 3.4 | ||||||
| Summary | 0006208: Cannot select scalar to vary radius of tube filter | ||||||||
| Description | The tube filter has a "Vary radius" option that allows you to vary the radius of the tube based on a scalar or vector. However, you are not able to select the scalar or vector to use. Instead, the active scalar or vector is taken. The tube filter should allow you to select the scalar or vector. Ideally, it would also automatically select scalars or vectors based on what variable the user selected. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0012813) Utkarsh Ayachit (administrator) 2008-07-24 13:45 |
This should be fixed. |
(0012828) Alan Scott (manager) 2008-07-25 12:53 |
Tested client/server. |
| Notes |
| Issue History | |||
| 2008-01-02 09:56 | Ken Moreland | New Issue | |
| 2008-04-08 16:44 | Ken Moreland | Category | => 3.4 |
| 2008-04-08 16:44 | Ken Moreland | Status | backlog => tabled |
| 2008-04-08 16:44 | Ken Moreland | Assigned To | => Berk Geveci |
| 2008-06-03 11:02 | Utkarsh Ayachit | Assigned To | Berk Geveci => Burlen |
| 2008-07-24 13:45 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2008-07-24 13:45 | Utkarsh Ayachit | Resolution | open => fixed |
| 2008-07-24 13:45 | Utkarsh Ayachit | Note Added: 0012813 | |
| 2008-07-25 12:53 | Alan Scott | Status | @80@ => closed |
| 2008-07-25 12:53 | Alan Scott | Note Added: 0012828 | |
| 2009-05-13 13:58 | Utkarsh Ayachit | Target Version | => 3.4 |
| 2009-05-13 13:59 | Utkarsh Ayachit | Fixed in Version | => 3.4 |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
