| 0006096 | ParaView | (No Category) | public | 2007-11-29 11:17 | 2011-01-13 17:00 | ||||
| Reporter | David Karelitz | ||||||||
| Assigned To | Ken Moreland | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Product Version | |||||||||
| Target Version | 3.4 | Fixed in Version | 3.4 | ||||||
| Summary | 0006096: Text is not scaled appropriately when rendering high-res movies | ||||||||
| Description | The Text source text is not scaled when rendering high-res movies. Ideally, when scaling the text up, it should examine the bounding box of the text in relation to the existing view size and scale the text appropriately so the relationship between the text bounding box and the view is maintained. Currently the text stays a fixed size when the view size changes leading to trial and error to make the text the right size in the right location | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0011168) Ken Moreland (manager) 2008-04-08 15:02 |
I recommend taking a look at the scalar bar widget implementation. It accepts font sizes (like the text widgets) but then scales them based on the window size (specifically, it assumes that the wider edge is 6in long). |
(0011989) Ken Moreland (manager) 2008-05-19 09:39 |
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqTextDisplayPropertiesWidget.ui,v <-- Qt/Components/Resources/UI/pqTextDisplayPropertiesWidget.ui new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Core/pqTextRepresentation.cxx,v <-- Qt/Core/pqTextRepresentation.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVScalarBarActor.cxx,v <-- Servers/Filters/vtkPVScalarBarActor.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVScalarBarActor.h,v <-- Servers/Filters/vtkPVScalarBarActor.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml new revision: 1.290; previous revision: 1.289 /cvsroot/ParaView3/ParaView3/VTK/Hybrid/vtkCaptionActor2D.cxx,v <-- VTK/Hybrid/vtkCaptionActor2D.cxx new revision: 1.37; previous revision: 1.36 /cvsroot/ParaView3/ParaView3/VTK/Rendering/vtkScaledTextActor.cxx,v <-- VTK/Rendering/vtkScaledTextActor.cxx new revision: 1.29; previous revision: 1.28 /cvsroot/ParaView3/ParaView3/VTK/Rendering/vtkTextActor.cxx,v <-- VTK/Rendering/vtkTextActor.cxx new revision: 1.45; previous revision: 1.44 /cvsroot/ParaView3/ParaView3/VTK/Rendering/vtkTextActor.h,v <-- VTK/Rendering/vtkTextActor.h new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/VTK/Widgets/vtkCaptionRepresentation.cxx,v <-- VTK/Widgets/vtkCaptionRepresentation.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/VTK/Widgets/vtkImagePlaneWidget.cxx,v <-- VTK/Widgets/vtkImagePlaneWidget.cxx new revision: 1.17; previous revision: 1.16 /cvsroot/ParaView3/ParaView3/VTK/Widgets/vtkTextRepresentation.cxx,v <-- VTK/Widgets/vtkTextRepresentation.cxx new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaViewData/Baseline/TextWidget.png,v <-- Baseline/TextWidget.png new revision: 1.5; previous revision: 1.4 |
(0012058) Alan Scott (manager) 2008-05-21 22:30 |
Tested client/server. |
| Notes |
| Issue History | |||
| 2007-11-29 11:17 | David Karelitz | New Issue | |
| 2008-04-08 14:55 | Ken Moreland | Status | backlog => tabled |
| 2008-04-08 14:55 | Ken Moreland | Assigned To | => Berk Geveci |
| 2008-04-08 14:55 | Ken Moreland | Category | Development => 3.4 |
| 2008-04-08 15:02 | Ken Moreland | Note Added: 0011168 | |
| 2008-05-01 13:46 | Berk Geveci | Assigned To | Berk Geveci => Ken Moreland |
| 2008-05-19 09:39 | Ken Moreland | Status | tabled => @80@ |
| 2008-05-19 09:39 | Ken Moreland | Resolution | open => fixed |
| 2008-05-19 09:39 | Ken Moreland | Note Added: 0011989 | |
| 2008-05-21 22:30 | Alan Scott | Status | @80@ => closed |
| 2008-05-21 22:30 | Alan Scott | Note Added: 0012058 | |
| 2009-05-13 13:58 | Utkarsh Ayachit | Target Version | => 3.4 |
| 2009-05-13 13:59 | Utkarsh Ayachit | Fixed in Version | => 3.4 |
| 2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
| 2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
| 2011-03-29 10:47 | Ken Moreland | Relationship added | related to 0012018 |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
