| 0005864 | ParaView | Bug | public | 2007-10-10 17:00 | 2016-08-12 09:57 | ||||
| Reporter | Dave DeMarle | ||||||||
| Assigned To | Dave DeMarle | ||||||||
| Priority | normal | Severity | feature | Reproducibility | always | ||||
| Status | closed | Resolution | moved | ||||||
| Product Version | |||||||||
| Target Version | Someday | Fixed in Version | |||||||
| Summary | 0005864: How to inspect the available time domain(s)? | ||||||||
| Description | It would be very nice to have a panel that lists the available time domains of all readers, sources and filters in the pipeline. Right now one has to navigate to the information tab of every filters Object Inspector Panel and then scribble down the values on a post-it note. The simplest thing to do would be to add a "Temporal Bounds" column to the Statistics View that lists the time ranges and/or discrete time samples for every dataset. It would be more intuitive to have a graphical representation of the same data. In this case one could visually see when temporal sources have overlapping or non overlapping ranges. Another useful addition would be a vertical bar that shows the current time. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0017069) Dave DeMarle (administrator) 2009-08-05 14:43 |
I am thinking of a waveform graph, which animation view is closest too. |
(0037546) Kitware Robot (administrator) 2016-08-12 09:57 |
| Notes |
| Issue History | |||
| 2007-10-10 17:00 | Dave DeMarle | New Issue | |
| 2007-10-11 13:17 | Dave DeMarle | Status | backlog => tabled |
| 2007-10-11 13:17 | Dave DeMarle | Assigned To | => Dave DeMarle |
| 2009-02-16 17:12 | Ken Moreland | Category | => Someday |
| 2009-05-13 13:49 | Utkarsh Ayachit | Target Version | => Someday |
| 2009-08-05 14:43 | Dave DeMarle | Note Added: 0017069 | |
| 2009-08-05 14:43 | Dave DeMarle | Category | => Bug |
| 2016-08-12 09:57 | Kitware Robot | Note Added: 0037546 | |
| 2016-08-12 09:57 | Kitware Robot | Status | expired => closed |
| 2016-08-12 09:57 | Kitware Robot | Resolution | open => moved |
| Issue History |
