| 0005662 | ParaView | (No Category) | public | 2007-09-06 14:50 | 2016-08-12 09:57 | ||||
| Reporter | Clinton Stimpson | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Status | closed | Resolution | moved | ||||||
| Product Version | |||||||||
| Target Version | Someday | Fixed in Version | |||||||
| Summary | 0005662: output messages from contour filter | ||||||||
| Description | create Octree Fractal source and hit apply create a contour filter and hit apply. I get: Tree has 190 leaves Tree has 190 leaves And sometimes I the following message if I change the Maximum Level on the Octree Fractal: Max depth 8, ids: 111 55 0 Neighbor 0 is a leaf with id 43. All neighbors are leaves. Terminate recursion. Looks like debug statements. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0014967) Ken Moreland (manager) 2009-02-16 16:12 |
These are probably just some debugging statements that should be commented out. |
(0015023) Utkarsh Ayachit (administrator) 2009-02-17 11:42 |
These are coming from vtkHyperOctree and they seem to be debug statements that are printed when some exception is reached. Since I am not too familiar with that piece of code, I am disinclined from removing those. I'll let them be for now. |
(0023880) Dave DeMarle (administrator) 2010-12-10 14:02 |
If we aren't supporting the Hyper Octree Dataset should we just remove the source to reduce confusion of users. |
(0037537) Kitware Robot (administrator) 2016-08-12 09:57 |
| Notes |
| Issue History | |||
| 2007-09-06 14:50 | Clinton Stimpson | New Issue | |
| 2008-04-15 09:40 | Berk Geveci | Status | backlog => @30@ |
| 2008-04-15 09:40 | Berk Geveci | Category | => 3.6 |
| 2009-02-16 16:12 | Ken Moreland | Status | @30@ => tabled |
| 2009-02-16 16:12 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
| 2009-02-16 16:12 | Ken Moreland | Note Added: 0014967 | |
| 2009-02-17 11:42 | Utkarsh Ayachit | Note Added: 0015023 | |
| 2009-02-17 11:43 | Utkarsh Ayachit | Category | 3.6 => Someday |
| 2009-05-13 13:49 | Utkarsh Ayachit | Target Version | => Someday |
| 2010-12-10 14:02 | Dave DeMarle | Note Added: 0023880 | |
| 2010-12-10 14:02 | Dave DeMarle | Status | tabled => @20@ |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| 2016-08-12 09:57 | Kitware Robot | Note Added: 0037537 | |
| 2016-08-12 09:57 | Kitware Robot | Status | expired => closed |
| 2016-08-12 09:57 | Kitware Robot | Resolution | open => moved |
| Issue History |
