| 0005016 | ParaView | (No Category) | public | 2007-05-10 15:51 | 2009-05-13 13:46 | ||||
| Reporter | Jon Goldman | ||||||||
| Assigned To | Ken Moreland | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Product Version | |||||||||
| Target Version | 3.6 | Fixed in Version | |||||||
| Summary | 0005016: simple 3-point CSV file -- nothing showing in 3D view | ||||||||
| Description | I have a very simple CSV file: X::Point,Y::Point,Z::Point 0,0,0 0,10,0 0,10,10 I load the data. Nothing shows up in the 3D view. I guess I expected to see a single triangle... Attached is an image snapshot from PV3. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0011748) Ken Moreland (manager) 2008-05-08 10:39 |
The support for CSV files is all messed up. We hope to address these issues in version 3.6 with better support for table data sets. I envision this scenario playing out as follows: 1. Load in the CSV file. The file becomes a table data type, which is shown by default in a spreadsheet view. Makes sense since it's basically just regurgitating the CSV contents. 2. Run a filter that imposes connectivity. Taking every three rows and making a triangle from those makes as much sense as anything else. |
(0014955) Ken Moreland (manager) 2009-02-16 15:19 |
Now CSV files are read as tables. There is a filter to convert tables to a poly data set with a bunch of vertex cells using some columns as coordinates. If you want a filter that provides other connectivity, either implement that as a programmable filter or issue another bug. |
(0014989) Alan Scott (manager) 2009-02-16 19:07 |
I could not get this to work. * I was able to read the CSV file into a table. * Table to Points and Table to Structured Grid then produced junk. Does it work for you? How did you get it to work? |
(0015024) Ken Moreland (manager) 2009-02-17 11:48 |
It works fine for me. I loaded in a CSV file with the contents exactly like those specified on this bug. I then ran Table To Points. I set X Column to X::Point, Y Column to Y::Point and Z Column to Z::Point. When I make the result visible in a 3D view, I get three points at exactly the coordinates specified in the CSV file. Did you perhaps forget to set the values for the X/Y/Z Column parameters of the Table To Points filter? |
(0015195) Alan Scott (manager) 2009-02-18 19:19 |
Tested local server. |
| Notes |
| Issue History | |||
| 2008-04-09 20:39 | Berk Geveci | Category | => 3.6 |
| 2008-05-08 10:39 | Ken Moreland | Note Added: 0011748 | |
| 2009-02-16 15:19 | Ken Moreland | Note Added: 0014955 | |
| 2009-02-16 15:19 | Ken Moreland | Status | tabled => @80@ |
| 2009-02-16 15:19 | Ken Moreland | Resolution | open => fixed |
| 2009-02-16 19:07 | Alan Scott | Assigned To | Berk Geveci => Ken Moreland |
| 2009-02-16 19:07 | Alan Scott | Note Added: 0014989 | |
| 2009-02-16 19:07 | Alan Scott | Status | @80@ => @20@ |
| 2009-02-16 19:07 | Alan Scott | Resolution | fixed => reopened |
| 2009-02-17 11:48 | Ken Moreland | Note Added: 0015024 | |
| 2009-02-17 11:48 | Ken Moreland | Status | @20@ => @80@ |
| 2009-02-17 11:48 | Ken Moreland | Resolution | reopened => fixed |
| 2009-02-18 19:19 | Alan Scott | Note Added: 0015195 | |
| 2009-02-18 19:19 | Alan Scott | Status | @80@ => closed |
| 2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
