| 0004355 | ParaView | (No Category) | public | 2007-01-22 19:23 | 2011-01-14 20:35 | ||||
| Reporter | Ken Moreland | ||||||||
| Assigned To | Clinton Stimpson | ||||||||
| Priority | low | Severity | major | Reproducibility | always | ||||
| Product Version | |||||||||
| Target Version | Someday | Fixed in Version | |||||||
| Summary | 0004355: Linked properties do not update GUI | ||||||||
| Description | When two objects are linked and the master object is changed, the slave object is properly updated, but the slave's associated GUI still shows the old values. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0006249) Clinton Stimpson (developer) 2007-01-23 16:39 |
/cvsroot/ParaView3/ParaView3/Qt/Core/pqPropertyLinks.cxx,v <-- pqPropertyLinks.cxx new revision: 1.5; previous revision: 1.4 |
(0006358) Ken Moreland (manager) 2007-02-05 19:27 |
The linked object's GUI is updated only after Apply is hit. Is it possible for the GUI to be updated immediately? |
(0006751) Clinton Stimpson (developer) 2007-03-12 18:12 |
That would probably require a global pqPropertyManager instance for the whole GUI, instead of local instances. |
(0006955) Clinton Stimpson (developer) 2007-03-27 12:17 |
Note to self: Actually, better fix would be to have a global pqPropertyManager::pqInternal::PropertyMap would probably fix this without changing any code elsewhere in ParaView. |
(0011120) Berk Geveci (administrator) 2008-04-07 16:43 |
Is this an issue? Fix if it is very easy to fix. Otherwise, put off until someone asks for it. |
(0024687) Utkarsh Ayachit (administrator) 2011-01-14 13:52 |
pretty sure this is fixed now. |
(0024699) Alan Scott (manager) 2011-01-14 20:35 |
I also believe that this is fixed. If not, please give directions on how to test. |
| Notes |
| Issue History | |||
| 2008-04-07 16:43 | Berk Geveci | Note Added: 0011120 | |
| 2008-04-07 16:43 | Berk Geveci | Status | backlog => tabled |
| 2008-04-07 16:43 | Berk Geveci | Category | => 3.4 |
| 2008-05-01 13:35 | Berk Geveci | Category | 3.4 => 3.6 |
| 2009-02-16 14:48 | Ken Moreland | Category | 3.6 => Someday |
| 2009-05-13 13:49 | Utkarsh Ayachit | Target Version | => Someday |
| 2011-01-14 13:52 | Utkarsh Ayachit | Note Added: 0024687 | |
| 2011-01-14 13:52 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2011-01-14 13:52 | Utkarsh Ayachit | Resolution | reopened => fixed |
| 2011-01-14 20:35 | Alan Scott | Note Added: 0024699 | |
| 2011-01-14 20:35 | Alan Scott | Status | @80@ => closed |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
