| 0016100 | ParaView | (No Category) | public | 2016-04-27 14:13 | 2016-08-12 10:00 | ||||
| Assigned To | Kitware Robot | ||||||||
| Status | closed | Resolution | moved | ||||||
| Product Version | 5.0.1 | ||||||||
| Summary | 0016100: Additional line with plot global data over time, in parallel. | ||||||||
| Description | This bug only shows in parallel, numerous mpi ranks, with number of ranks less than or equal to number of files. Basically, the end point is connected back to the first point in the plot global data over time. * Linux, 8 pvservers, 5.0.1. * Load z_pinch1.8.[0-7]. Load all variables. Apply. * Plot global data over time. Apply. * Turn off all variables. Turn on variable ZMON. <<Bug>> Notice the straight line going back to the start. This is a bug. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0039045) Kitware Robot (administrator) 2016-08-12 10:00 |
| Notes |
| Issue History | |||
| 2016-04-27 14:13 | Alan Scott | New Issue | |
| 2016-08-12 10:00 | Kitware Robot | Note Added: 0039045 | |
| 2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
| 2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
| 2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
| Issue History |
