| 0015843 | ParaView | (No Category) | public | 2015-11-18 20:31 | 2016-01-08 15:32 | ||||
| Product Version | 5.0 | ||||||||
| Target Version | 5.0 | Fixed in Version | 5.0 | ||||||
| Summary | 0015843: RC1 5.0 fails running normal, new, powerful Mesa | ||||||||
| Description | I have a remote build of PV 5.5.0, RC1. When I run ParaView, I get the following in the output window: Warning: In /projects/viz/paraview/src/ParaView/5.0.0-junk/ParaView4/VTK/Rendering/OpenGL2/vtkOpenGLRenderWindow.cxx, line 549 vtkOSOpenGLRenderWindow (0x1451d00): VTK is designed to work with OpenGL version 3.2 but it appears it has been given a context that does not support 3.2. VTK will run in a compatibility mode designed to work with OpenGL 2.1 but some features may not work. I then try to open a cylinder, and get the following on the client side: ERROR: In /projects/viz/paraview/src/ParaView/5.0.0-junk/ParaView4/VTK/Rendering/OpenGL2/vtkShaderProgram.cxx, line 370 vtkShaderProgram (0x4005bd0): 0:2(12): error: extension `GL_EXT_gpu_shader4' unsupported in fragment shader ERROR: In /projects/viz/paraview/src/ParaView/5.0.0-junk/ParaView4/VTK/Common/Core/vtkDataArrayTemplate.txx, line 142 vtkUnsignedCharArray (0x62558d0): Unable to allocate 3757531591590 elements of size 1 bytes. Server side looks like this: Connecting to client (reverse connection requested)... Connection URL: csrc://ceerws2213:11111 Client connected. GL_Version: 3.0 Mesa 11.0.4 GL_Version: 3.0 Mesa 11.0.4 GL_Version: 3.0 Mesa 11.0.4 GL_Version: 3.0 Mesa 11.0.4 GL_Version: 3.0 Mesa 11.0.4 GL_Version: 3.0 Mesa 11.0.4 GL_Version: 3.0 Mesa 11.0.4 GL_Version: 3.0 Mesa 11.0.4 and Warning: In /projects/viz/paraview/src/ParaView/5.0.0-junk/ParaView4/VTK/Rendering/OpenGL2/vtkOpenGLRenderWindow.cxx, line 549 vtkOSOpenGLRenderWindow (0xb26ba0): VTK is designed to work with OpenGL version 3.2 but it appears it has been given a context that does not support 3.2. VTK will run in a compatibility mode designed to work with OpenGL 2.1 but some features may not work. ERROR: In /projects/viz/paraview/src/ParaView/5.0.0-junk/ParaView4/VTK/Rendering/OpenGL2/vtkShaderProgram.cxx, line 370 vtkShaderProgram (0x4005bd0): 0:2(12): error: extension `GL_EXT_gpu_shader4' unsupported in fragment shader However!!!!!!!!!!!! Mesa 11.0.4 is OpenGL 4.1 compliant! So, what's going on? Due to stupid stuff in Mesa (internet search says something about patents), Mesa 11.0.4 implements OpenGL 4.1, but a glGetString(GL_VERSION) returns that it is only OGL 3.0 compliant. Hack to get around it: set MESA_GL_VERSION_OVERRIDE=3.2 But, we must have ParaView work as follows: * Work with new Mesa, without having to set an environment variable. * Work with older versions of Mesa (at least for a while), and never, never crash. | ||||||||
| Project | TBD | ||||||||
| Topic Name | |||||||||
| Type | crash | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0035471) Alan Scott (manager) 2015-11-18 20:35 |
OK to make project Sandia if appropriate. |
(0035495) Ken Martin (reporter) 2015-12-01 14:55 |
Yes, so MESA seems like an odd beast in that Mesa supports recent OpenGL versions but some of its drivers do not. I believe the pure software driver works fine. This page shows a nice list of drivers that do support all that we need https://secure.freedesktop.org/~imirkin/glxinfo/glxinfo.html#v=Mesa%2011.0.0 [^] but we still need to gracefully handle the case where Mesa is using a hardware accelerated driver that is tied to old hardware. I have made the SupportsOpenGL() method work in VTK/OpenGL2 so that PV should be able to gracefully query for support prior to trying to render and handle it nicely. With that we should be able to track down what Mesa drivers are causing issues. |
(0035526) Utkarsh Ayachit (administrator) 2015-12-09 11:09 |
https://gitlab.kitware.com/paraview/paraview/merge_requests/511 [^] commit de35af0f480253442ea209e62dc311bda919296e Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Dec 9 11:00:41 2015 -0500 BUG 0015843: Add support to test OpenGL version. Added checks during initialization of a session to validate OpenGL version support. If not adequate a dialog will be popped up warning about the same. If the OpenGL version of server side alone is inadequate, then remote rendering is disabled. If OpenGL version on client is inadequate, then we pop up a dialog and abort. |
(0035553) Alan Scott (manager) 2015-12-14 15:22 |
Much better. Tested Linux, master, remote server (Chama). |
| Notes |
| Issue History | |||
| 2015-11-18 20:31 | Alan Scott | New Issue | |
| 2015-11-18 20:32 | Alan Scott | Relationship added | related to 0015842 |
| 2015-11-18 20:35 | Alan Scott | Note Added: 0035471 | |
| 2015-11-18 20:35 | Alan Scott | Target Version | => 5.0 |
| 2015-12-01 14:55 | Ken Martin | Note Added: 0035495 | |
| 2015-12-09 11:09 | Utkarsh Ayachit | Note Added: 0035526 | |
| 2015-12-09 11:09 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2015-12-09 11:09 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2015-12-09 11:09 | Utkarsh Ayachit | Resolution | open => fixed |
| 2015-12-09 11:09 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2015-12-14 09:35 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2015-12-14 15:22 | Alan Scott | Note Added: 0035553 | |
| 2015-12-14 15:22 | Alan Scott | Status | customer review => closed |
| 2016-01-08 15:32 | Utkarsh Ayachit | Fixed in Version | git-master => 5.0 |
| Issue History |
