| 0015593 | ParaView | (No Category) | public | 2015-07-22 17:05 | 2016-06-09 10:58 | ||||
| Product Version | git-master | ||||||||
| Target Version | 5.1 | Fixed in Version | 5.1 | ||||||
| Summary | 0015593: Screenshots of comparative view fail | ||||||||
| Description | Trying to take a screenshot of comparative views fails miserably. * Linux, master, local server. * Open can. Apply. * Convert the view to a comparative view. Make visible. <<Minor bug>> The can should be visible as we toggle from renderview to renderview(comparative) * File/ Save Screenshot. ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx, line 390 vtkPVSessionCore (0x1c570e0): Object type: vtkPVComparativeView, could not find requested method: "PrepareForScreenshot" or the method was called with incorrect arguments. while processing Message 0 = Invoke Argument 0 = stream_value { Message 0 = Invoke Argument 0 = id_value {1} Argument 1 = string_value {GetVTKObject} Argument 2 = uint32_value {9032} } Argument 1 = string_value {PrepareForScreenshot} ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx, line 391 vtkPVSessionCore (0x1c570e0): Aborting execution for debugging purposes. ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx, line 390 vtkPVSessionCore (0x1c570e0): Object type: vtkPVComparativeView, could not find requested method: "CleanupAfterScreenshot" or the method was called with incorrect arguments. while processing Message 0 = Invoke Argument 0 = stream_value { Message 0 = Invoke Argument 0 = id_value {1} Argument 1 = string_value {GetVTKObject} Argument 2 = uint32_value {9032} } Argument 1 = string_value {CleanupAfterScreenshot} ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx, line 391 vtkPVSessionCore (0x1c570e0): Aborting execution for debugging purposes. Save Image failed. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0035871) Utkarsh Ayachit (administrator) 2016-04-03 21:44 |
MR: https://gitlab.kitware.com/paraview/paraview/merge_requests/718 [^] |
(0035891) Alan Scott (manager) 2016-04-15 22:10 |
Nice. Tested Linux, master, local server. |
| Notes |
| Issue History | |||
| 2015-07-22 17:05 | Alan Scott | New Issue | |
| 2015-07-22 17:26 | Alan Scott | Target Version | => 4.5 |
| 2015-09-11 16:44 | Utkarsh Ayachit | Target Version | 4.5 => 5.1 |
| 2016-02-11 20:53 | Alan Scott | Summary | Screenshots of comparitive view fail => Screenshots of comparative view fail |
| 2016-02-11 20:53 | Alan Scott | Description Updated | |
| 2016-04-03 21:43 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2016-04-03 21:43 | Utkarsh Ayachit | Status | backlog => active development |
| 2016-04-03 21:44 | Utkarsh Ayachit | Note Added: 0035871 | |
| 2016-04-07 09:05 | Utkarsh Ayachit | Status | active development => customer review |
| 2016-04-07 09:05 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2016-04-07 09:05 | Utkarsh Ayachit | Resolution | open => fixed |
| 2016-04-15 22:10 | Alan Scott | Note Added: 0035891 | |
| 2016-04-15 22:10 | Alan Scott | Status | customer review => closed |
| 2016-06-09 10:58 | Utkarsh Ayachit | Fixed in Version | git-master => 5.1 |
| Issue History |
