| 0015457 | ParaView | (No Category) | public | 2015-05-06 21:21 | 2015-09-06 12:18 | ||||
| Product Version | |||||||||
| Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
| Summary | 0015457: Image stack, slice representation don't work in parallel | ||||||||
| Description | Multiple servers fails when trying to represent a slice representation. * Linux, master, 4 servers. * Load the Turtle tiff stack (Utkarsh has this). Read as image stack. Use custom data spacing. Custom Data Spacing == 1,1,1. Apply. * Change the representation to slice. You will only get visibility on one of the processes. Further, another dataset (that I cannot give out) actually crashes. Here is some of the error verbiage: RROR: In .../ParaView4/VTK/Common/ExecutionMode/vtkStreamingDemandDrivenPipeline.cxx, line 847 vtkStreamingDemandDrivenPipeline (0x1c92090): The update extent specified in the information for output port 0 on algorithm vtkTrivialProducer(0x1c878d0) is 0 906 0 806 267 267, which is outside the whole extent 0 453 0 403 0 535. ERROR: In .../ParaView4/VTK/Common/ExecutionModel/vtkTrivialProducer.cxx, line 279 vtkTrivialProducer (0x1c878d0): This data object does not contain the requested extent. Warning: In .../ParaView4/ParaViewCore/VTKExtensions/Rendering/vtkTexturePainter.cxx, line 188 vtkTexturePainter (0x717bf60): Failed to locate selected scalars. Will use image scalars by default. ERROR: In .../ParaView4/VTK/Common/ExecutionModel/vtkStreamingDemandDrivenPipeline.cxx, line 847 vtkStreamingDemandDrivenPipeline (0x9632cf0): The update extent specified in the information for output port 0 on algorithm vtkTrivialProducer(0x9632860) is 0 906 0 806 267 267, which is outside the whole extent 0 453 0 403 0 535. ERROR: In .../ParaView4/VTK/Common/ExecutionModel/vtkTrivialProducer.cxx, line 279 vtkTrivialProducer (0x9632860): This data object does not contain the requested extent. Warning: In .../ParaView4/ParaViewCore/VTKExtensions/Rendering/vtkTexturePainter.cxx, line 188 vtkTexturePainter (0x717bf60): Failed to locate selected scalars. Will use image scalars by default. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0034406) Utkarsh Ayachit (administrator) 2015-05-08 17:45 |
Merge request: https://gitlab.kitware.com/paraview/paraview/merge_requests/92 [^] |
(0034407) Utkarsh Ayachit (administrator) 2015-05-09 08:39 |
merged in master. |
(0034451) Alan Scott (manager) 2015-06-02 21:29 |
Excellent, works like a charm. Tested Linux, master, remote server. Used the Turtle tiff stack. |
| Notes |
| Issue History | |||
| 2015-05-06 21:21 | Alan Scott | New Issue | |
| 2015-05-06 21:22 | Alan Scott | Target Version | => 4.4 |
| 2015-05-07 08:29 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2015-05-08 17:45 | Utkarsh Ayachit | Note Added: 0034406 | |
| 2015-05-08 17:45 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2015-05-08 17:45 | Utkarsh Ayachit | Resolution | open => fixed |
| 2015-05-09 08:39 | Utkarsh Ayachit | Note Added: 0034407 | |
| 2015-05-09 08:39 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2015-05-09 08:39 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2015-06-02 21:29 | Alan Scott | Note Added: 0034451 | |
| 2015-06-02 21:29 | Alan Scott | Status | customer review => closed |
| 2015-09-06 12:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
| Issue History |
