| 0015445 | ParaView | (No Category) | public | 2015-05-01 17:32 | 2015-09-06 12:17 | ||||
| Product Version | git-master | ||||||||
| Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
| Summary | 0015445: d3 has lots of warnings (Errors) | ||||||||
| Description | I have a user that is experiencing hangs with d3. Although I can't replicate it on an open dataset, I can replicate the warning and error messages that are printed out. Here is how to do it. * Linux, master, 8 remote pvservers. * Open dataset LargeTiedBlocks-out.par.48.[0-47] All vars on. Apply. (Utkarsh should have this dataset already.] * Clip. Apply. * D3. Apply. Lots of error messages. Here are some: ceesrv02:bin$ Accepting connection(s): ceesrv02:11111 ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/VTK/Filters/Parallel/vtkPKdTree.cxx, line 344 vtkPKdTree (0xea7b440): (process 0) VolumeBounds - degenerate volume ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/VTK/Filters/ParallelMPI/vtkDistributedDataFilter.cxx, line 796 vtkDistributedDataFilter (0xe7b6480): Unable to build k-d tree structure ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/VTK/Filters/ParallelMPI/vtkDistributedDataFilter.cxx, line 623 vtkDistributedDataFilter (0xe7b6480): vtkDistributedDataFilter::Execute k-d tree failure ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/VTK/Filters/Parallel/vtkPKdTree.cxx, line 344 vtkPKdTree (0xea79ae0): (process 0) VolumeBounds - degenerate volume ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/VTK/Filters/ParallelMPI/vtkDistributedDataFilter.cxx, line 796 vtkDistributedDataFilter (0xe7b6480): Unable to build k-d tree structure ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/VTK/Filters/ParallelMPI/vtkDistributedDataFilter.cxx, line 623 vtkDistributedDataFilter (0xe7b6480): vtkDistributedDataFilter::Execute k-d tree failure ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/VTK/Filters/Parallel/vtkPKdTree.cxx, line 344 vtkPKdTree (0xea7d4f0): (process 0) VolumeBounds - degenerate volume ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/VTK/Filters/ParallelMPI/vtkDistributedDataFilter.cxx, line 796 vtkDistributedDataFilter (0xe7b6480): Unable to build k-d tree structure | ||||||||
| Project | Sandia | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0034645) Utkarsh Ayachit (administrator) 2015-07-02 10:48 |
Tried with: v4.3.1-770-ge93cf36 Cannot reproduce. With 2 pvservers or 8 pvservers, I nicely get each "vertebra" distributed among as many pvserver ranks after D3 is applied. |
(0034740) Utkarsh Ayachit (administrator) 2015-07-10 10:30 |
(don't forget the clip) |
(0034742) Utkarsh Ayachit (administrator) 2015-07-10 11:28 edited on: 2015-07-14 09:24 |
Merge requests: VTK: https://gitlab.kitware.com/vtk/vtk/merge_requests/400 [^] ParaView: https://gitlab.kitware.com/paraview/paraview/merge_requests/217 [^] |
(0034776) Utkarsh Ayachit (administrator) 2015-07-14 13:26 |
Fix merged. |
(0034793) Alan Scott (manager) 2015-07-16 21:05 |
Excellent. Tested remote server, Linux, master. |
| Notes |
| Issue History | |||
| 2015-05-01 17:32 | Alan Scott | New Issue | |
| 2015-05-01 17:33 | Alan Scott | Target Version | => 4.4 |
| 2015-07-02 10:48 | Utkarsh Ayachit | Note Added: 0034645 | |
| 2015-07-02 10:48 | Utkarsh Ayachit | Status | backlog => customer review |
| 2015-07-02 10:48 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2015-07-02 10:48 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
| 2015-07-02 10:48 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2015-07-10 10:30 | Utkarsh Ayachit | Status | customer review => todo |
| 2015-07-10 10:30 | Utkarsh Ayachit | Note Added: 0034740 | |
| 2015-07-10 11:28 | Utkarsh Ayachit | Note Added: 0034742 | |
| 2015-07-14 05:15 | Utkarsh Ayachit | Status | todo => gatekeeper review |
| 2015-07-14 05:15 | Utkarsh Ayachit | Resolution | unable to reproduce => fixed |
| 2015-07-14 09:24 | Utkarsh Ayachit | Note Edited: 0034742 | |
| 2015-07-14 13:26 | Utkarsh Ayachit | Note Added: 0034776 | |
| 2015-07-14 13:26 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2015-07-16 21:05 | Alan Scott | Note Added: 0034793 | |
| 2015-07-16 21:05 | Alan Scott | Status | customer review => closed |
| 2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
| Issue History |
