| 0015437 | ParaView | (No Category) | public | 2015-04-29 10:39 | 2015-09-06 12:17 | ||||
| Reporter | Mathieu Westphal | ||||||||
| Product Version | 4.3 | ||||||||
| Target Version | Fixed in Version | 4.4 | |||||||
| Summary | 0015437: Multipiece dataset selection tools select data on the first piece only | ||||||||
| Description | When working with a multipiece dataset, selecting cells or point in the dataset through the renderview bouton interface will result in a selection in the first block. "Select Cells on", "Select points on", "Select cells with polygon", "Select point with polygon", "Select block" have this issue. Only "Select Cells/Points through" works as expected. | ||||||||
| Steps To Reproduce | Open the attached file in ParaView master - it is a multipiece dataset. Select some cells or points. | ||||||||
| Project | TBD | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0034454) Utkarsh Ayachit (administrator) 2015-06-03 11:00 |
https://gitlab.kitware.com/paraview/paraview/merge_requests/138 [^] |
(0034510) Utkarsh Ayachit (administrator) 2015-06-04 22:25 |
Merged and added a test "TestSelectionOnMultipiece". |
(0034762) Alan Scott (manager) 2015-07-10 21:53 |
Tested master, remote server, Linux. |
| Notes |
| Issue History | |||
| 2015-04-29 10:39 | Mathieu Westphal | New Issue | |
| 2015-04-29 10:39 | Mathieu Westphal | File Added: bugMultiPiece.tgz | |
| 2015-05-12 03:52 | Joachim Pouderoux | Summary | Multipiece dataset selection systemically select data from first block => Multipiece dataset selection systemically selects data from first piece |
| 2015-05-12 03:52 | Joachim Pouderoux | Description Updated | |
| 2015-05-12 03:52 | Joachim Pouderoux | Steps to Reproduce Updated | |
| 2015-05-12 03:53 | Joachim Pouderoux | Summary | Multipiece dataset selection systemically selects data from first piece => Multipiece dataset selection tools select data on the first piece only |
| 2015-05-13 09:47 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2015-06-03 10:59 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2015-06-03 10:59 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2015-06-03 10:59 | Utkarsh Ayachit | Resolution | open => fixed |
| 2015-06-03 11:00 | Utkarsh Ayachit | Note Added: 0034454 | |
| 2015-06-04 22:25 | Utkarsh Ayachit | Note Added: 0034510 | |
| 2015-06-04 22:25 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2015-06-22 09:13 | Utkarsh Ayachit | Relationship added | related to 0015377 |
| 2015-07-10 21:53 | Alan Scott | Note Added: 0034762 | |
| 2015-07-10 21:53 | Alan Scott | Status | customer review => closed |
| 2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
| Issue History |
