| 0015414 | ParaView | (No Category) | public | 2015-04-07 09:23 | 2016-08-12 09:59 | ||||
| Reporter | Loïc Chevallier | ||||||||
| Assigned To | Kitware Robot | ||||||||
| Status | closed | Resolution | moved | ||||||
| Product Version | 4.3 | ||||||||
| Summary | 0015414: Bug with cut-lines (plotOverLine): wrong element found when searching for the point inside | ||||||||
| Description | I found a bug in Paraview, any version (3 and 4 tested) when making a cut-line (PlotOverLine filter in ParaView 4). Details and data (in french only) are available on code_Carmel website : http://code-carmel.univ-lille1.fr/fr/node/286. [^] Summarizing, ParaView may not find the element which contains a given point (in the cut-line). And thus give a wrong result, significant sometimes. This is not due to a lack of accuracy. It occurs with MED (SALOME and PARAVIS module) and VTK file formats (ParaView release), the only one tested. A bug ticket was also created on the SALOME site (http://salome-platform.org [^]). Best regards, Loïc Chevallier. | ||||||||
| Project | ParaViS | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0038798) Kitware Robot (administrator) 2016-08-12 09:59 |
| Notes |
| Issue History | |||
| 2015-04-07 09:23 | Loïc Chevallier | New Issue | |
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038798 | |
| 2016-08-12 09:59 | Kitware Robot | Status | backlog => closed |
| 2016-08-12 09:59 | Kitware Robot | Resolution | open => moved |
| 2016-08-12 09:59 | Kitware Robot | Assigned To | => Kitware Robot |
| Issue History |
