| 0015411 | VTK | (No Category) | public | 2015-04-06 07:28 | 2016-07-21 14:21 | ||||
| Reporter | Edson Tadeu M. Manoel | ||||||||
| Assigned To | |||||||||
| Product Version | 6.0.0 | ||||||||
| Summary | 0015411: vtkSTLReader is not able to read STL file with multiple patches | ||||||||
| Description | NOTE: I've already opened a merge request here: https://gitlab.kitware.com/vtk/vtk/merge_requests/89 [^] If we have an ASCII STL file with multiple patches, in the format: <code> solid wing_1 facet normal -0.988028 0.000000 -0.154276 outer loop vertex 5.111373 2.636347 1.956025 vertex 5.111609 3.636347 1.948793 vertex 5.111373 3.636347 1.956025 endloop endfacet facet normal -0.988028 -0.000000 -0.154276 outer loop vertex 5.111609 3.636347 1.948793 vertex 5.111373 2.636347 1.956025 vertex 5.111609 2.636347 1.948793 endloop endfacet ... facet normal -0.000004 1.000000 -0.000004 outer loop vertex 5.322488 2.636348 1.971589 vertex 5.111609 2.636347 1.948793 vertex 5.118849 2.636347 1.940065 endloop endfacet endsolid wing_1 solid wing_2 facet normal -0.988028 0.000000 -0.154275 outer loop vertex 5.516308 2.636347 2.030015 vertex 5.514788 3.636347 2.022941 vertex 5.516308 3.636347 2.030015 endloop endfacet facet normal -0.988028 -0.000000 -0.154275 outer loop vertex 5.514788 3.636347 2.022941 vertex 5.516308 2.636347 2.030015 vertex 5.514788 2.636347 2.022941 endloop endfacet ... facet normal -0.000004 1.000000 -0.000004 outer loop vertex 5.724917 2.636348 1.994043 vertex 5.514788 2.636347 2.022941 vertex 5.519701 2.636347 2.012721 endloop endfacet endsolid wing_2 </code> The vtkSTLReader is not able to read it, giving the following error: <code> vtkSTLReader (...): STLReader: error while reading file ... at line ...: unable to read reading point. </code> | ||||||||
| Project | TBD | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0036541) Haocheng Liu (developer) 2016-07-21 14:21 |
Fixed in MR!592. |
| Notes |
| Issue History | |||
| 2015-04-06 07:28 | Edson Tadeu M. Manoel | New Issue | |
| 2016-07-06 16:47 | Berk Geveci | Status | backlog => expired |
| 2016-07-21 14:21 | Haocheng Liu | Note Added: 0036541 | |
| 2016-07-21 14:21 | Haocheng Liu | Status | expired => closed |
| 2016-07-21 14:21 | Haocheng Liu | Resolution | open => fixed |
| Issue History |
