| 0015338 | ParaView | (No Category) | public | 2015-02-23 15:30 | 2015-09-06 12:18 | ||||
| Product Version | git-master | ||||||||
| Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
| Summary | 0015338: Save current settings as default (Properties) - logic error | ||||||||
| Description | When you want to Save current settings as default (properties section), there is a very surprising and confusing logic bug. This is that you can click on the Save current settings as default before hitting the Apply, but it silently doesn't work. Please fix this. * Linux, master, local server. * Sources/ Sphere. Apply. * Filters/ Calculator. Result name == X_DIFF. Formula == coordsX-Normals_X. * Save current settings values as default (Properties section). (Note that you have not yet hit Apply.) * Edit/ Reset Session. * Sources/ Sphere. Apply. * Filters/ Calculator. Note that the formula is not filled out. Either make the Properties section of the Properties tab be saved correctly even before an apply is clicked, put up a warning message that nothing is being done, or best of all, gray out the Save current settings values as default icon when it really isn't active. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0034343) Utkarsh Ayachit (administrator) 2015-04-07 13:27 |
Awaiting review: https://gitlab.kitware.com/paraview/paraview/merge_requests/44 [^] |
(0034346) Utkarsh Ayachit (administrator) 2015-04-07 21:36 |
Merged in master: https://gitlab.kitware.com/paraview/paraview/commit/1eba63cfaf99f93a58a417678c4c2eabfdf5c8ed [^] |
(0034385) Alan Scott (manager) 2015-04-29 22:24 |
Tested master, Linux, local server. |
| Notes |
| Issue History | |||
| 2015-02-23 15:30 | Alan Scott | New Issue | |
| 2015-02-23 15:30 | Alan Scott | Target Version | => 4.4 |
| 2015-04-07 08:50 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2015-04-07 13:27 | Utkarsh Ayachit | Note Added: 0034343 | |
| 2015-04-07 13:27 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2015-04-07 13:27 | Utkarsh Ayachit | Resolution | open => fixed |
| 2015-04-07 21:36 | Utkarsh Ayachit | Note Added: 0034346 | |
| 2015-04-07 21:36 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2015-04-07 21:36 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2015-04-29 22:24 | Alan Scott | Note Added: 0034385 | |
| 2015-04-29 22:24 | Alan Scott | Status | customer review => closed |
| 2015-09-06 12:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
| Issue History |
