| 0015276 | ParaView | (No Category) | public | 2015-01-22 09:43 | 2016-08-12 09:59 | ||||
| Assigned To | Kitware Robot | ||||||||
| Status | closed | Resolution | moved | ||||||
| Product Version | |||||||||
| Summary | 0015276: Merge blocks fails when merging structured grids. | ||||||||
| Description | See http://markmail.org/message/fvatgidqbvnufgi6#query:+page:1+mid:bncapqmxha4v7zjc+state:results [^] | ||||||||
| Project | TBD | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0034103) Alan Scott (manager) 2015-01-22 21:47 |
I was able to replicate with the datasets available in the link above. I tried can.exo, was not able to replicate the bug. Linux, 4.3.1, local server. Loaded the datasets with the visit version of the tecplot reader. Group datasets. Merge Blocks. Hole between the two strips shows. Reset Linux, 4.3.1, local server. Loaded the datasets with the non-visit version of the tecplot reader. Group datasets. Merge Blocks. Following error shows, but the object looks OK on screen: ERROR: In /projects/viz/paraview/src/ParaView/4.3.1/ParaView4/VTK/Common/ExecutionModel/vtkStreamingDemandDrivenPipeline.cxx, line 857 vtkStreamingDemandDrivenPipeline (0x90a29e0): The update extent specified in the information for output port 0 on algorithm vtkTrivialProducer(0x22dc530) is 0 40 0 8 0 0, which is outside the whole extent 0 28 0 8 0 0. |
(0038764) Kitware Robot (administrator) 2016-08-12 09:59 |
| Notes |
| Issue History | |||
| 2015-01-22 09:43 | Utkarsh Ayachit | New Issue | |
| 2015-01-22 21:47 | Alan Scott | Note Added: 0034103 | |
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038764 | |
| 2016-08-12 09:59 | Kitware Robot | Status | backlog => closed |
| 2016-08-12 09:59 | Kitware Robot | Resolution | open => moved |
| 2016-08-12 09:59 | Kitware Robot | Assigned To | => Kitware Robot |
| Issue History |
