| 0015065 | VTK | (No Category) | public | 2014-10-22 17:01 | 2015-02-11 14:18 | ||||
| Reporter | Orion Poplawski | ||||||||
| Assigned To | Ben Boeckel (Kitware) | ||||||||
| Product Version | 6.0.0 | ||||||||
| Target Version | Fixed in Version | 6.2.0 | |||||||
| Summary | 0015065: Do not use get_filename_component to determine VTK_INSTALL_PREFIX | ||||||||
| Description | On systems with /lib64 -> /usr/lib64 (Fedora UsrMove), VTKConfig.cmake incorrectly set VTK_INSTALL_PREFIX to "/", resulting in "//include/vtk" in VTK_INCLUDE_DIRS. VTK_INSTALL_PREFIX is known at compile/install time and should be set accordingly. | ||||||||
| Project | TBD | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0034148) Orion Poplawski (reporter) 2015-02-03 18:00 |
This appears to be fixed in VTK git and can probably be closed. |
(0034150) Orion Poplawski (reporter) 2015-02-03 18:33 |
Sorry, my mistake, this is still an issue: CMake/vtkModuleTop.cmake: # Generate VTKConfig.cmake for the install tree. set(VTK_CONFIG_CODE " # Compute the installation prefix from this VTKConfig.cmake file location. get_filename_component(VTK_INSTALL_PREFIX \"\${CMAKE_CURRENT_LIST_FILE}\" PATH)") # Construct the proper number of get_filename_component(... PATH) # calls to compute the installation prefix. string(REGEX REPLACE "/" ";" _count "${VTK_INSTALL_PACKAGE_DIR}") foreach(p ${_count}) set(VTK_CONFIG_CODE "${VTK_CONFIG_CODE} get_filename_component(VTK_INSTALL_PREFIX \"\${VTK_INSTALL_PREFIX}\" PATH)") endforeach() |
(0034163) Dave DeMarle (administrator) 2015-02-05 12:13 |
@Ben, please take a look and see if this is as trivial to fix as it looks and decide on 6.2 or 6.3 target. |
(0034198) Ben Boeckel (Kitware) (developer) 2015-02-09 15:54 |
http://review.source.kitware.com/#/t/5446 [^] |
(0034207) Brad King (developer) 2015-02-11 10:41 |
VTK should use the approach that CMake does for install(EXPORT) here: http://www.cmake.org/gitweb?p=cmake.git;a=blob;f=Source/cmExportInstallFileGenerator.cxx;hb=v3.1.2#l72 [^] Basically it saves knowledge of the original install prefix, and if the current location is just a symlink to that, it uses the original instead of the symlinked path. |
(0034210) Ben Boeckel (Kitware) (developer) 2015-02-11 14:18 |
Merged. |
| Notes |
| Issue History | |||
| 2014-10-22 17:01 | Orion Poplawski | New Issue | |
| 2015-02-03 18:00 | Orion Poplawski | Note Added: 0034148 | |
| 2015-02-03 18:33 | Orion Poplawski | Note Added: 0034150 | |
| 2015-02-05 12:12 | Dave DeMarle | Assigned To | => Ben Boeckel (Kitware) |
| 2015-02-05 12:13 | Dave DeMarle | Note Added: 0034163 | |
| 2015-02-09 15:54 | Ben Boeckel (Kitware) | Note Added: 0034198 | |
| 2015-02-09 15:54 | Ben Boeckel (Kitware) | Status | backlog => gerrit review |
| 2015-02-11 10:41 | Brad King | Note Added: 0034207 | |
| 2015-02-11 14:18 | Ben Boeckel (Kitware) | Note Added: 0034210 | |
| 2015-02-11 14:18 | Ben Boeckel (Kitware) | Status | gerrit review => closed |
| 2015-02-11 14:18 | Ben Boeckel (Kitware) | Resolution | open => fixed |
| 2015-02-11 14:18 | Ben Boeckel (Kitware) | Fixed in Version | => 6.2.0 |
| Issue History |
