| 0014996 | ParaView | (No Category) | public | 2014-09-15 16:56 | 2016-08-12 09:59 | ||||
| Reporter | Andy Bauer | ||||||||
| Status | closed | Resolution | moved | ||||||
| Product Version | git-master | ||||||||
| Summary | 0014996: Ensight reader has problems with 14 processes | ||||||||
| Description | When trying to read in an Ensight file with 14 processes (doesn't seem to cause problems with less processes) I get the following error: ERROR: In /home/acbauer/CODE/ParaView/ParaView-v4.1.0/VTK/Common/DataModel/vtkDataSet.cxx, line 414 vtkStructuredGrid (0xa70560): Point array DENS with 1 components, only has -325 tuples but there are 0 points Steps to reproduce: 1) start pvserver with 14 processes 2) connect the client 3) load the naca.bin.case file in ParaViewData in Data/Ensight This was on an ubuntu 12.04 machine with GCC 4.6.4 and OpenMPI 1.4.3. | ||||||||
| Project | TBD | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0033366) Andy Bauer (developer) 2014-09-17 13:13 |
Using files that Mike Stephens shared with me, I can reproduce a similar problem. The files are at /home/acbauer/DATA/ERDC/STEPHENS/EnsightIssue-9-16-2014/wing/wpfsFlow.case (they can't be shared outside of Kitware). Steps to reproduce: 1) run pvserver with 14 processes 2) connect a client 3) load the file 4) use the extract block filter to extract any of the "Patch = *" files There won't be any fields defined over the grid in this case. If the file is loaded into PV with the built-in server then all blocks have fields defined over them. |
(0038656) Kitware Robot (administrator) 2016-08-12 09:59 |
| Notes |
| Issue History | |||
| 2014-09-15 16:56 | Andy Bauer | New Issue | |
| 2014-09-15 16:56 | Andy Bauer | Assigned To | => Utkarsh Ayachit |
| 2014-09-17 13:13 | Andy Bauer | Note Added: 0033366 | |
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038656 | |
| 2016-08-12 09:59 | Kitware Robot | Status | backlog => closed |
| 2016-08-12 09:59 | Kitware Robot | Resolution | open => moved |
| Issue History |
