| 0013382 | VTK | (No Category) | public | 2012-08-21 05:31 | 2015-08-27 07:01 | ||||
| Reporter | Tim Hutton | ||||||||
| Assigned To | T.J. Corona | ||||||||
| Product Version | 5.8.0 | ||||||||
| Summary | 0013382: vtkXMLUnstructuredGridWriter: corrupted output for polyhedral cells in appended mode | ||||||||
| Description | The Graphics\Cxx\TestPolyhedron0.cxx test works in ASCII mode, but comment-out this line and it breaks: writer->SetDataModeToAscii(); Alternatively, explicitly change it to: writer->SetDataModeToAppended(); (Binary mode works fine.) The resulting vtu file has malformed XML. It starts like this: " offset="588"="1.0"?> <VTKFile type="UnstructuredGrid" version="0.1" byte_order="LittleEndian" compressor="vtkZLibDataCompressor"> <UnstructuredGrid> ...etc." Still an issue in VTK 5.10.0. An improved test would try all the different data modes (ascii, binary, appended) and compressors (zlib, none). | ||||||||
| Project | TBD | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||||||||||||
| Relationships |
| Notes | |
(0033671) Lars Bilke (reporter) 2014-10-28 02:48 |
This is still an issue in 6.1 on Mac OS X 10.9 |
(0034877) Menno Deij (reporter) 2015-08-04 09:53 |
This is still an issue in origin/master. |
(0035070) T.J. Corona (developer) 2015-08-26 15:39 |
I am having trouble reproducing this bug. Can you run the test under lldb with Guard Malloc on (env DYLD_INSERT_LIBRARIES=/usr/lib/libgmalloc.dylib)? |
(0035075) Menno Deij (reporter) 2015-08-27 02:14 |
This bug was resolved after this request was merged https://gitlab.kitware.com/vtk/vtk/merge_requests/501 [^] If you are testing on origin/master that maybe why it is not reproduceable? Also, see the attached data https://gitlab.kitware.com/vtk/vtk/uploads/5a809cfb40449e6ec58a96028a01906e/grid_only_0_0.zip [^] to have a test case. |
(0035076) T.J. Corona (developer) 2015-08-27 06:59 |
Thanks for the explanation! I will close this ticket then. |
(0035077) T.J. Corona (developer) 2015-08-27 07:01 |
This issue was fixed in commit https://gitlab.kitware.com/vtk/vtk/commit/f2fd417af9fdb4d92a87f3bd5e2cb888a82b0883 [^] |
| Notes |
| Issue History | |||
| 2012-08-21 05:31 | Tim Hutton | New Issue | |
| 2013-06-25 14:23 | Dave DeMarle | Relationship added | related to 0013860 |
| 2013-06-25 14:23 | Dave DeMarle | Relationship added | related to 0013295 |
| 2013-06-25 14:24 | Dave DeMarle | Relationship added | related to 0013294 |
| 2014-10-28 02:48 | Lars Bilke | Note Added: 0033671 | |
| 2015-08-04 09:53 | Menno Deij | Note Added: 0034877 | |
| 2015-08-26 15:39 | T.J. Corona | Note Added: 0035070 | |
| 2015-08-27 02:14 | Menno Deij | Note Added: 0035075 | |
| 2015-08-27 06:59 | T.J. Corona | Note Added: 0035076 | |
| 2015-08-27 07:01 | T.J. Corona | Note Added: 0035077 | |
| 2015-08-27 07:01 | T.J. Corona | Status | backlog => closed |
| 2015-08-27 07:01 | T.J. Corona | Assigned To | => T.J. Corona |
| 2015-08-27 07:01 | T.J. Corona | Resolution | open => fixed |
| Issue History |
