| 0013174 | VTK | (No Category) | public | 2012-05-14 11:47 | 2014-10-02 17:10 | ||||
| Reporter | Sean McBride | ||||||||
| Assigned To | Chuck Atkins | ||||||||
| Status | closed | Resolution | unable to reproduce | ||||||
| Product Version | |||||||||
| Summary | 0013174: incremental build dependency problem toggling VTK_USE_64BIT_IDS | ||||||||
| Description | Repro: - build VTK 5.10rc4 with BUILD_TESTING=1 - toggle VTK_USE_64BIT_IDS from its default - don't 'clean' - rebuild Results: - link errors: Undefined symbols for architecture x86_64: "__ZN12LSDynaFamily10SkipToWordENS_11SectionTypeEii", referenced from: __ZN15vtkLSDynaReader21ReadHeaderInformationEi in libvtkIO.a(vtkLSDynaReader.cxx.o) __ZN15vtkLSDynaReader21ScanDatabaseTimeStepsEv in libvtkIO.a(vtkLSDynaReader.cxx.o) __ZN15vtkLSDynaReader9ReadNodesEv in libvtkIO.a(vtkLSDynaReader.cxx.o) __ZN15vtkLSDynaReader11ReadUserIdsEv in libvtkIO.a(vtkLSDynaReader.cxx.o) __ZN15vtkLSDynaReader17ReadNodeStateInfoEi in libvtkIO.a(vtkLSDynaReader.cxx.o) __ZN15vtkLSDynaReader12ReadSPHStateEi in libvtkIO.a(vtkLSDynaReader.cxx.o) __ZN15vtkLSDynaReader19ReadUserMaterialIdsEv in libvtkIO.a(vtkLSDynaReader.cxx.o) ... VTK has an incremental build dependency problem. When you build and then change the setting of VTK_USE_64BIT_IDS, and rebuild, Utilities/LSDyna sees the one definition of vtkIdType (64bit), and the rest of the build sees the other (32bit) (or vice versa). Doing a 'make clean' and then a 'make' is a workaround. A proper bug fix is to make CMake aware that changing this flag requires a complete rebuild (like compiler flags do). | ||||||||
| Tags | hackaton | ||||||||
| Project | TBD | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0029317) Sean McBride (developer) 2012-10-03 17:57 |
Hit this again trying today's origin/release (soon to be 5.10.1) |
(0031243) Dave DeMarle (administrator) 2013-07-22 20:02 |
moving all "tabled" bugs into "backlog" category since "tabled" is no longer used. |
(0033549) Chuck Atkins (developer) 2014-10-02 17:10 |
Tested with master on 64 bit Linux, Mac, and Windows (vs2010 x64). Was not able to reproduce when toggling the boolean and rebuilding. |
| Notes |
| Issue History | |||
| 2012-05-14 11:47 | Sean McBride | New Issue | |
| 2012-05-14 11:47 | Sean McBride | Status | backlog => tabled |
| 2012-05-14 11:47 | Sean McBride | Assigned To | => Dave DeMarle |
| 2012-10-03 17:57 | Sean McBride | Note Added: 0029317 | |
| 2013-07-22 20:02 | Dave DeMarle | Status | tabled => backlog |
| 2013-07-22 20:02 | Dave DeMarle | Note Added: 0031243 | |
| 2014-09-30 11:01 | Dave DeMarle | Assigned To | Dave DeMarle => |
| 2014-10-02 11:37 | Berk Geveci | Tag Attached: hackaton | |
| 2014-10-02 11:38 | Berk Geveci | Assigned To | => Chuck Atkins |
| 2014-10-02 15:35 | Chuck Atkins | Status | backlog => active development |
| 2014-10-02 17:10 | Chuck Atkins | Note Added: 0033549 | |
| 2014-10-02 17:10 | Chuck Atkins | Status | active development => closed |
| 2014-10-02 17:10 | Chuck Atkins | Resolution | open => unable to reproduce |
| Issue History |
