| 0012952 | ParaView | (No Category) | public | 2012-02-20 17:59 | 2012-05-21 23:37 | ||||
| Assigned To | Alan Scott | ||||||||
| Priority | urgent | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | git-master | ||||||||
| Summary | 0012952: Crash when transforming 2d image | ||||||||
| Description | We have a crash when trying to transform a fairly large 2d image. I will attach the image. Windows, master, local serve. Open file Left_Eye_0003.jpg. Apply. Transform. Change the "Translate - X" entry to different things. I tried 1, then 10, then 100, etc. Repeat. You will crash, probably running out of memory. This is happening at line 312 in vtkQuadricClustering.cxx in Start Append. We are trying to do a new in the X, Y and Z direction. In the current crash, these are (this->NumberoOfDivisions) of 160, 160, 160, which creates an amazingly large number. Further, this should be a 2d object! This needs to be fixed. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | |||||||||
| Type | crash | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0028396) Utkarsh Ayachit (administrator) 2012-03-26 16:24 |
Alan, can you attach the dataset? thanks. |
(0028625) Alan Scott (manager) 2012-05-21 23:37 |
I just tried this bug once again, and it appears to be fixed. Tested master, Windows, local server. I used Kevin's Ball/ Mass/ Left/ Left_eye_0000.jpg |
| Notes |
| Issue History | |||
| 2012-02-20 17:59 | Alan Scott | New Issue | |
| 2012-03-26 16:24 | Utkarsh Ayachit | Note Added: 0028396 | |
| 2012-05-21 23:37 | Alan Scott | Note Added: 0028625 | |
| 2012-05-21 23:37 | Alan Scott | Status | backlog => closed |
| 2012-05-21 23:37 | Alan Scott | Assigned To | => Alan Scott |
| 2012-05-21 23:37 | Alan Scott | Resolution | open => fixed |
| Issue History |
