| 0012786 | VTK | (No Category) | public | 2011-12-09 09:35 | 2012-04-16 20:22 | ||||
| Reporter | Pavel Pokutnev | ||||||||
| Assigned To | Lisa Avila | ||||||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | 5.8.0 | ||||||||
| Summary | 0012786: BUG in vtkFixedPointVolumeRayCastMapper | ||||||||
| Description | There are some int overflow bugs in vtkFixedPointVolumeRayCastMapper, if used with big volumes [2000 * 2000 * 2000] > [max(int) = 2147483647] and shading enabled. BUG 1: Line 2787 / 2788 int sliceSize = dim[0]*dim[1]*((independent)?(components):(1)); int numSlices = dim[2]; should be: vtkIdType sliceSize = dim[0]*dim[1]*((independent)?(components):(1)); vtkIdType numSlices = dim[2]; because of line 2840, 2848, … where the actual int overflow happens (numSlices * sliceSize)! BUG 2: Line 98 int x, y, z; should be: vtkIdType x, y, z; because of line 171, where the actual int overflow happens (dptr = dataPtr + z * dim[0] * dim[1] + y * dim[0] + xlow;) Attached to this bug report you will find the fixed version of vtkFixedPointVolumeRayCastMapper.cxx. | ||||||||
| Project | TBD | ||||||||
| Type | crash | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0028316) David Gobbi (developer) 2012-02-21 18:03 |
This bug should be fixed by the following commits, which were merged into master on Feb 21, 2012: ba9d3759ff57d36007318d21811042ba414442e1 aacb6cf3acab9a25d5ec445056f7d16b778fa935 |
(0028481) David Gobbi (developer) 2012-04-16 20:22 |
The bug was fixed by the following commit: a3feef0dff8ab684fa6c3834f6e7a67ad3af37f1 BUG 12810: Fix for int overflows in volume rendering module. Use vtkIdType for increment calculations in order to avoid 32-bit overflow in the volume mapper. Commit was merged into master on April 7, 2012, and fix will be present in VTK 6.0. The merge commit is as follows: fc4c570a71cdc1deede305d8bfa8e014f811ffa2 Fix was verified by user on April 16, 2012. |
| Notes |
| Issue History | |||
| 2011-12-09 09:35 | Pavel Pokutnev | New Issue | |
| 2011-12-09 09:35 | Pavel Pokutnev | File Added: vtkFixedPointVolumeRayCastMapper.cxx | |
| 2011-12-09 09:56 | Utkarsh Ayachit | Assigned To | => Lisa Avila |
| 2011-12-09 09:56 | Utkarsh Ayachit | Status | backlog => tabled |
| 2012-02-21 18:03 | David Gobbi | Note Added: 0028316 | |
| 2012-04-16 20:22 | David Gobbi | Note Added: 0028481 | |
| 2012-04-16 20:22 | David Gobbi | Status | tabled => closed |
| 2012-04-16 20:22 | David Gobbi | Resolution | open => fixed |
| Issue History |
