0012744VTK(No Category)public2011-11-22 09:012016-08-12 09:55
ReporterDavid Partyka
Assigned ToDavid Partyka
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version5.8.0
Target Version5.8.1Fixed in Version
Summary0012744: VTKTargets installation location issues
DescriptionPlease review the following 4 changes. I think they might be helpful.
* VTK_TARGETS_FILE was defined twice
* adding #include <cstring> was necessary for gcc-4.6
On a Debian system I am installing into /usr/lib/
* VTKTargets.cmake gets installed in the same folder as the libs (in
my case /usr/lib/ but I need them in /usr/lib/vtk-5.8)
* libPath always points to /usr/lib/vtk-5.8 (please don't apply this
patch, it's just to show you that something is wrong)
Thanks
Dominique
--- vtk-5.8.0.orig/vtkGenerateVTKConfig.cmake
+++ vtk-5.8.0/vtkGenerateVTKConfig.cmake
@@ -147,9 +147,6 @@ SET(VTK_TCL_TK_MACROS_MODULE_CONFIG
    "${VTK_CMAKE_DIR}/vtkTclTkMacros.cmake")
 SET(VTK_CMAKE_EXTENSIONS_DIR_CONFIG ${VTK_BINARY_DIR}/CMake)
-# Export Targets file.
-SET(VTK_TARGETS_FILE "${VTK_BINARY_DIR}/${VTK_INSTALL_EXPORT_NAME}.cmake")
 # Build configuration information.
 SET(VTK_CONFIGURATION_TYPES_CONFIG ${CMAKE_CONFIGURATION_TYPES})
 SET(VTK_BUILD_TYPE_CONFIG ${CMAKE_BUILD_TYPE})
--- vtk-5.8.0.orig/Utilities/DICOMParser/DICOMParser.cxx
+++ vtk-5.8.0/Utilities/DICOMParser/DICOMParser.cxx
@@ -41,6 +41,7 @@
 #include <string.h>
 #include <string>
+#include <cstring>
 // Define DEBUG_DICOM to get debug messages sent to dicom_stream::cerr
 // #define DEBUG_DICOM
--- vtk-5.8.0.orig/Utilities/LastConfigureStep/CMakeLists.txt
+++ vtk-5.8.0/Utilities/LastConfigureStep/CMakeLists.txt
@@ -11,7 +11,7 @@
 GET_PROPERTY(VTK_TARGETS GLOBAL PROPERTY VTK_TARGETS)
 EXPORT(TARGETS ${VTK_TARGETS} FILE
${VTK_BINARY_DIR}/${VTK_INSTALL_EXPORT_NAME}.cmake)
-INSTALL(EXPORT ${VTK_INSTALL_EXPORT_NAME} DESTINATION
${VTK_INSTALL_LIB_DIR_CM24})
+INSTALL(EXPORT ${VTK_INSTALL_EXPORT_NAME} DESTINATION
${VTK_INSTALL_PACKAGE_DIR_CM24})
 GET_PROPERTY(VTK_LIBRARIES GLOBAL PROPERTY VTK_LIBRARIES)
 # Create the VTKConfig.cmake file containing the VTK configuration.
--- vtk-5.8.0.orig/Wrapping/Tcl/pkgIndex.tcl.in
+++ vtk-5.8.0/Wrapping/Tcl/pkgIndex.tcl.in
@@ -5,6 +5,7 @@ package ifneeded vtkinit {@VTK_MAJOR_VER
    proc load_library_package {libName libPath {libPrefix
{@VTK_TCL_LIBNAME_PREFIX@}}} {
      set libExt [info sharedlibextension]
      set currentDirectory [pwd]
+ set libPath /usr/@VTK_INSTALL_LIB_DIR@/
      set libFile [file join $libPath "$libPrefix$libName$libExt"]
      if {[catch "cd {$libPath}; load {$libFile}" errorMessage]} {
        puts $errorMessage
TagsNo tags attached.
ProjectTBD
Typeincorrect functionality
 Relationships
  Notes
(0031263)
Dave DeMarle (administrator)
2013-07-22 20:03
moving all "tabled" bugs into "backlog" category since "tabled" is no longer used.
(0031280)
2013-07-22 20:33
Dave P no longer works on the project. If these old issues still exist in 6.0.0, reopen them and assign to Dave DeMarle
(0037255)
Kitware Robot (administrator)
2016-08-12 09:55
Resolving issue as `moved`.
This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page.
 Issue History
2011-11-22 09:01 David Partyka New Issue
2011-11-22 09:01 David Partyka Status backlog => tabled
2011-11-22 09:01 David Partyka Assigned To => David Partyka
2011-11-22 09:01 David Partyka Product Version => 5.8.0
2011-11-22 09:01 David Partyka Target Version => 5.8.1
2013-07-22 20:03 Dave DeMarle Status tabled => backlog
2013-07-22 20:03 Dave DeMarle Note Added: 0031263
2013-07-22 20:33 Dave DeMarle Status backlog => expired
2013-07-22 20:33 Dave DeMarle Note Added: 0031280
2016-08-12 09:55 Kitware Robot Note Added: 0037255
2016-08-12 09:55 Kitware Robot Status expired => closed
2016-08-12 09:55 Kitware Robot Resolution open => moved
