| 0012693 | VTK | (No Category) | public | 2011-11-01 04:53 | 2014-01-27 07:32 | ||||
| Reporter | Andreas Buykx | ||||||||
| Assigned To | David Partyka | ||||||||
| Product Version | 5.8.0 | ||||||||
| Target Version | 5.8.1 | Fixed in Version | |||||||
| Summary | 0012693: vtkMPASReader.cxx defines global variable PI | ||||||||
| Description | vtk-5.8.0-source/IO/vtkMPASReader.cxx, line 104 defines a global variable PI. double PI = 3.141592; This global variable (of very limited precision) can easily clash with other definitions of PI, as in our case with a global PI in OpenCascade. This can easily lead to very hard to detect bugs: we spent roughly 5 man days until we found this ... It looks like the variable declaration can safely be changed into a static declaration, hiding the variable from the global namespace. | ||||||||
| Project | TBD | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0027660) Sean McBride (developer) 2011-11-04 15:53 |
http://review.source.kitware.com/3207 [^] |
(0027671) Sean McBride (developer) 2011-11-08 15:08 |
This is now fixed in git master. |
(0031264) Dave DeMarle (administrator) 2013-07-22 20:03 |
moving all "tabled" bugs into "backlog" category since "tabled" is no longer used. |
(0031279) Dave DeMarle (administrator) 2013-07-22 20:33 |
Dave P no longer works on the project. If these old issues still exist in 6.0.0, reopen them and assign to Dave DeMarle |
(0032222) Andreas Buykx (reporter) 2014-01-27 07:32 |
Code review of 6.1.0: no PI found in header anymore. Issue can be closed as far as I'm concerned. |
| Notes |
| Issue History | |||
| 2011-11-01 04:53 | Andreas Buykx | New Issue | |
| 2011-11-01 08:48 | David Partyka | Assigned To | => David Partyka |
| 2011-11-01 08:48 | David Partyka | Status | backlog => tabled |
| 2011-11-01 08:49 | David Partyka | Target Version | => 5.8.1 |
| 2011-11-04 15:53 | Sean McBride | Note Added: 0027660 | |
| 2011-11-08 15:08 | Sean McBride | Note Added: 0027671 | |
| 2011-11-08 16:00 | Sean McBride | Source_changeset_attached | => VTK master 70fa8325 |
| 2011-11-08 16:00 | Sean McBride | Source_changeset_attached | => VTK master f3a01308 |
| 2011-11-11 16:00 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 1802e01c |
| 2013-07-22 20:03 | Dave DeMarle | Status | tabled => backlog |
| 2013-07-22 20:03 | Dave DeMarle | Note Added: 0031264 | |
| 2013-07-22 20:33 | Dave DeMarle | Status | backlog => expired |
| 2013-07-22 20:33 | Dave DeMarle | Note Added: 0031279 | |
| 2014-01-27 07:32 | Andreas Buykx | Note Added: 0032222 | |
| 2014-01-27 07:32 | Andreas Buykx | Status | expired => closed |
| 2014-01-27 07:32 | Andreas Buykx | Resolution | open => fixed |
| Issue History |
