| 0012586 | VTK | (No Category) | public | 2011-09-10 07:34 | 2016-08-12 09:55 | ||||
| Reporter | skific | ||||||||
| Assigned To | David Partyka | ||||||||
| Status | closed | Resolution | moved | ||||||
| Product Version | 5.8.0 | ||||||||
| Target Version | 5.8.1 | Fixed in Version | |||||||
| Summary | 0012586: vtkhdf5 include dirs for cpp build not present when HDF5_BUILD_CPP_LIB is ON | ||||||||
| Description | This happened when building vtk 5.8 (checkout from git tagged 5.8) in vs 2010 with cmake 2.8.5 I had enabled the HDF5_BUILD_CPP_LIB option in cmake-gui. However, the HDF5_INCLUDE_DIRS variable in vtkHDF5Config.cmake in buid/Utilities/vtkhdf5 does not hold the PATH_TO_VTK_SRC/Utilities/vtkhdf5/c++/src folder required for using hdf5's c++ classes. Consequently, the VTK_INCLUDE_DIRS variable has all vtkhdf5 folders, except for the c++/src folder. | ||||||||
| Project | TBD | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0031284) Dave DeMarle (administrator) 2013-07-22 20:33 |
Dave P no longer works on the project. If these old issues still exist in 6.0.0, reopen them and assign to Dave DeMarle |
(0037243) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
| Notes |
| Issue History | |||
| 2011-09-10 07:34 | skific | New Issue | |
| 2011-09-12 10:08 | David Partyka | Assigned To | => David Partyka |
| 2011-09-12 10:08 | David Partyka | Status | backlog => tabled |
| 2011-09-14 14:37 | David Partyka | Status | tabled => backlog |
| 2011-09-14 14:37 | David Partyka | Product Version | => 5.8.0 |
| 2011-09-14 14:37 | David Partyka | Target Version | => 5.8.1 |
| 2013-07-22 20:33 | Dave DeMarle | Status | backlog => expired |
| 2013-07-22 20:33 | Dave DeMarle | Note Added: 0031284 | |
| 2016-08-12 09:55 | Kitware Robot | Note Added: 0037243 | |
| 2016-08-12 09:55 | Kitware Robot | Status | expired => closed |
| 2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
| Issue History |
