| 0012521 | ParaView | (No Category) | public | 2011-08-15 14:22 | 2012-02-08 17:21 | ||||
| Assigned To | Kyle Lutz | ||||||||
| Product Version | |||||||||
| Target Version | 4.0 | Fixed in Version | 3.14 | ||||||
| Summary | 0012521: Summary Panel for sources/filters | ||||||||
| Description | http://paraview.org/ParaView3/index.php/ParaView_Usability_Improvements#Style_for_Object_Inspector_Summary_Panel [^] * Similar to what's shown at the link, except, we possibly add an Apply button between the two property groups. * Should be xml-hint configurable * Possibility to control values shown in the simplified panel using the Context-Menu (values changed from context-menu should auto-apply). | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 12521-summary-panel | ||||||||
| Type | feature | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0027673) Kyle Lutz (viewer) 2011-11-09 09:33 |
Merge topic '12521-summary-panel' into next 9b671ba Fix delete button enable state issues in pqSummaryPanel 7402f60 Fix bug in pqChartSummaryDisplayPanel c62e318 Use QPointer for pqProxy in pqObjectPanel 7ef9224 Add property links for calculator summary panel 04cdd2f Add new, empty panels for 3d widget sources d9cce3d Initial commit for the new Summary Panel b9c5583 Fix tests for new dock widgets 02f2ca9 Update VTK to bring in UncheckedPropertyModifedEvent |
(0027724) Utkarsh Ayachit (administrator) 2011-11-18 14:54 |
merged to master. |
(0027816) Kyle Lutz (viewer) 2011-12-14 10:07 |
Merge topic '12521-summary-panel' into next 45cc250 Fix unused variable warning in pqSurfaceLICSummaryDisplayPanel |
(0027820) Kyle Lutz (viewer) 2011-12-14 15:28 |
Merge topic '12521-summary-panel' into next 7e86ee8 Fix shadowed variable warnings in pqSummaryPanel |
(0027821) Kyle Lutz (viewer) 2011-12-14 16:08 |
Merge topic '12521-summary-panel' into next 9587f48 Fix more shadowed variable warnings for summary panels |
(0027822) Kyle Lutz (viewer) 2011-12-15 09:38 |
Merge topic '12521-summary-panel' into next 03732f4 Fix shadowed variable warning in pqSurfaceLICSummaryDisplayPanel |
(0027830) Utkarsh Ayachit (administrator) 2011-12-19 15:14 |
merged into master (wherever applicable) |
(0027850) Utkarsh Ayachit (administrator) 2011-12-19 15:15 |
(0027902) Kyle Lutz (viewer) 2012-01-05 15:43 |
Merge topic '12521-summary-panel' into next d1f34ab Merge branch 'reorder-summary-panel-arg' into 12521-summary-panel 2ace157 Fix issues with 3D widgets and summary panels d50faac Reorder the summaryOnly argument in pqAutoGeneratedObjectPanel |
(0027915) Kyle Lutz (viewer) 2012-01-06 17:28 |
Merge topic '12521-summary-panel' into next 077ed70 Fix memory leak when using 3D widgets |
(0027919) Kyle Lutz (viewer) 2012-01-07 13:38 |
Merge topic '12521-summary-panel' into next 4f0580f Fix unused argument warning in pq3DWidgetFactory |
(0027920) Kyle Lutz (viewer) 2012-01-07 13:41 |
Merge topic '12521-summary-panel' into next b5d2fcb Fix shadowed variable warning in pqStandardSummaryPanelImplementation |
(0027930) Kyle Lutz (viewer) 2012-01-10 16:21 |
Merge topic '12521-summary-panel' into next 2dad8f7 Fix 3D widgets reg_group in pq3DWidgetFactory 5005c4f Fix bug with 3D widgets when changing views |
(0027932) Kyle Lutz (viewer) 2012-01-11 15:34 |
Merge topic '12521-summary-panel' into next 1acd12e Revert "Fix issues with 3D widgets and summary panels" c6e9e1d Revert "Fix bug with 3D widgets when changing views" |
(0028005) Kyle Lutz (viewer) 2012-01-30 15:44 |
Merge topic '12521-summary-panel' into next c8b9cac Disable the summary panel 6911124 Fix summary panel bug on Windows XP |
(0028026) Utkarsh Ayachit (administrator) 2012-02-03 15:06 |
merged into master, where applicable. |
(0028038) Utkarsh Ayachit (administrator) 2012-02-03 15:06 |
(0028109) Alan Scott (manager) 2012-02-08 15:21 |
We are going to re-open another bug when we start putting summary panels back in, as per Utkarsh. |
| Notes |
| Issue History | |||
| 2011-08-15 14:22 | Utkarsh Ayachit | New Issue | |
| 2011-08-15 14:29 | Utkarsh Ayachit | Target Version | => 4.0 |
| 2011-08-15 14:31 | Utkarsh Ayachit | Type | incorrect functionality => feature |
| 2011-08-16 13:03 | Kyle Lutz | Assigned To | => Kyle Lutz |
| 2011-08-16 13:03 | Kyle Lutz | Status | backlog => todo |
| 2011-08-16 13:03 | Kyle Lutz | Status | todo => active development |
| 2011-11-09 09:33 | Kyle Lutz | Note Added: 0027673 | |
| 2011-11-09 09:33 | Kyle Lutz | Topic Name | => 12521-summary-panel |
| 2011-11-09 09:33 | Kyle Lutz | Status | active development => gatekeeper review |
| 2011-11-09 09:33 | Kyle Lutz | Fixed in Version | => 4.0 |
| 2011-11-09 09:33 | Kyle Lutz | Resolution | open => fixed |
| 2011-11-11 17:06 | Utkarsh Ayachit | Fixed in Version | 4.0 => git-master |
| 2011-11-18 14:54 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2011-11-18 14:54 | Utkarsh Ayachit | Note Added: 0027724 | |
| 2011-12-14 10:06 | Kyle Lutz | Status | customer review => todo |
| 2011-12-14 10:07 | Kyle Lutz | Note Added: 0027816 | |
| 2011-12-14 10:07 | Kyle Lutz | Status | todo => gatekeeper review |
| 2011-12-14 15:28 | Kyle Lutz | Note Added: 0027820 | |
| 2011-12-14 16:08 | Kyle Lutz | Note Added: 0027821 | |
| 2011-12-15 09:38 | Kyle Lutz | Note Added: 0027822 | |
| 2011-12-19 15:14 | Utkarsh Ayachit | Note Added: 0027830 | |
| 2011-12-19 15:15 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2011-12-19 15:15 | Utkarsh Ayachit | Note Added: 0027850 | |
| 2012-01-05 15:43 | Kyle Lutz | Status | customer review => todo |
| 2012-01-05 15:43 | Kyle Lutz | Note Added: 0027902 | |
| 2012-01-05 15:43 | Kyle Lutz | Status | todo => gatekeeper review |
| 2012-01-06 14:51 | Utkarsh Ayachit | Status | gatekeeper review => todo |
| 2012-01-06 17:28 | Kyle Lutz | Note Added: 0027915 | |
| 2012-01-06 17:28 | Kyle Lutz | Status | todo => gatekeeper review |
| 2012-01-07 13:38 | Kyle Lutz | Note Added: 0027919 | |
| 2012-01-07 13:41 | Kyle Lutz | Note Added: 0027920 | |
| 2012-01-10 16:21 | Kyle Lutz | Note Added: 0027930 | |
| 2012-01-11 15:34 | Kyle Lutz | Note Added: 0027932 | |
| 2012-01-13 13:54 | Utkarsh Ayachit | Status | gatekeeper review => backlog |
| 2012-01-13 13:54 | Utkarsh Ayachit | Resolution | fixed => reopened |
| 2012-01-30 15:44 | Kyle Lutz | Note Added: 0028005 | |
| 2012-01-30 15:44 | Kyle Lutz | Status | backlog => gatekeeper review |
| 2012-01-30 15:44 | Kyle Lutz | Resolution | reopened => fixed |
| 2012-02-03 15:06 | Utkarsh Ayachit | Note Added: 0028026 | |
| 2012-02-03 15:06 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-02-03 15:06 | Utkarsh Ayachit | Note Added: 0028038 | |
| 2012-02-08 15:21 | Alan Scott | Note Added: 0028109 | |
| 2012-02-08 15:21 | Alan Scott | Status | customer review => closed |
| 2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
| Issue History |
