| 0012469 | ParaView | (No Category) | public | 2011-08-03 16:29 | 2012-02-08 17:21 | ||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | 3.12 | ||||||||
| Target Version | 4.0 | Fixed in Version | 3.14 | ||||||
| Summary | 0012469: Research adding total dataset footprint to statistics view | ||||||||
| Description | There is a very large need to tell users how much memory ParaView is using. This is especially important on large clusters such as cray systems, that do not allow a user to log into the nodes and see how much memory is being used. This bug asks that Kitware research how hard it would be to either provide the user with the memory footprint of ParaView, or the memory footprint of the geometry and variable data. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 12469_memory_inspector | ||||||||
| Type | performance | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0027632) Alan Scott (manager) 2011-10-31 18:48 |
From an e-mail thread: Utkrash, We discussed the need for ParaView to return it’s memory footprint a few weeks ago, and this is becoming a huge issue on clusters. We believe this ability must reside in ParaView. I discussed with Robert, and he didn’t go running for the hills. I would like to propose that ParaView present a user with the following information: • This applies to Linux remote server only. • This applies to only those systems that have one system call supported – for instance, free or “cat /proc/meminfo”. However, this one call must be supported on Cielo (and I would guess all Cray systems). • Memory returned for a node as opposed to a core or process is fine (i.e., we don’t need the granularity of per core or pvserver memory.). Just do a free, report that. • Could be presented on the information tab, or on the statistics view, or a new menu – whatever is easier. • It would be acceptable if this was a special filter, only updated when the “apply” button is hit. • It would be acceptable if this was only updated when a user hit some button, or once every 5 seconds, or when a new filter came in or a filter was changed. • Swap files are never used with these systems – ignore that level of granularity. Average processes: • Total memory use per node. • Memory free per node. Lowest memory process: • Total memory use per node. • Memory free per node. • If possible, node number, or node name, or at least pvserver number. I think you get the point – having any solution would solve 90% of my current issues, no matter how rough this solution was. This is becoming a crisis on Cielo, as we are scaling to larger and larger numbers of nodes, on huge data. I need to know why we are dying. Alan |
(0027728) Utkarsh Ayachit (administrator) 2011-11-21 18:59 |
commit 6dbeaee5c927b00e9d4718f4a80a3451112d7445 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Nov 21 18:57:35 2011 -0500 Fixed BUG 0012469. Added new memory-inspector panel. * Added vtkPVSystemInformation to gather system information from all processes. * Added dock-panel to show memory information collected using vtkPVSystemInformation. * Updated CustomSourceProbe test to test the memory inspector panel as well. |
(0027759) Utkarsh Ayachit (administrator) 2011-12-02 14:26 |
merged into git-master. |
(0027814) Utkarsh Ayachit (administrator) 2011-12-14 09:30 |
reopening due to warnings. |
(0027815) Utkarsh Ayachit (administrator) 2011-12-14 09:31 |
commit 70b096959993e4a42ae14c0678c1ec44a7560020 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Dec 14 09:30:17 2011 -0500 Fixed warnings |
(0027828) Utkarsh Ayachit (administrator) 2011-12-19 15:14 |
merged into master (wherever applicable) |
(0027848) Utkarsh Ayachit (administrator) 2011-12-19 15:15 |
(0028087) Alan Scott (manager) 2012-02-07 22:10 |
Spectacular!! We have needed this functionality for a very long time. Thanks. Tested remote server, Linux, master. |
| Notes |
| Issue History | |||
| 2011-08-03 16:29 | Alan Scott | New Issue | |
| 2011-10-31 18:48 | Alan Scott | Note Added: 0027632 | |
| 2011-11-01 10:26 | Utkarsh Ayachit | Target Version | => 4.0 |
| 2011-11-07 13:44 | Utkarsh Ayachit | Assigned To | => Yumin Yuan |
| 2011-11-21 11:58 | Utkarsh Ayachit | Assigned To | Yumin Yuan => Utkarsh Ayachit |
| 2011-11-21 18:59 | Utkarsh Ayachit | Topic Name | => 12469_memory_inspector |
| 2011-11-21 18:59 | Utkarsh Ayachit | Note Added: 0027728 | |
| 2011-11-21 18:59 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2011-11-21 18:59 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2011-11-21 18:59 | Utkarsh Ayachit | Resolution | open => fixed |
| 2011-12-02 14:25 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2011-12-02 14:26 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2011-12-02 14:26 | Utkarsh Ayachit | Note Added: 0027759 | |
| 2011-12-14 09:30 | Utkarsh Ayachit | Note Added: 0027814 | |
| 2011-12-14 09:30 | Utkarsh Ayachit | Status | customer review => backlog |
| 2011-12-14 09:30 | Utkarsh Ayachit | Resolution | fixed => reopened |
| 2011-12-14 09:31 | Utkarsh Ayachit | Note Added: 0027815 | |
| 2011-12-14 09:31 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2011-12-14 09:31 | Utkarsh Ayachit | Fixed in Version | git-master => git-next |
| 2011-12-14 09:31 | Utkarsh Ayachit | Resolution | reopened => fixed |
| 2011-12-19 15:14 | Utkarsh Ayachit | Note Added: 0027828 | |
| 2011-12-19 15:15 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2011-12-19 15:15 | Utkarsh Ayachit | Note Added: 0027848 | |
| 2011-12-19 15:16 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2012-02-07 22:10 | Alan Scott | Note Added: 0028087 | |
| 2012-02-07 22:10 | Alan Scott | Status | customer review => closed |
| 2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
| Issue History |
