| Attached Files | vtkSocket.patch [^] (18,085 bytes) 2011-04-14 14:06 [Show Content] [Hide Content]--- VTK/Common/vtkSocket.h 2011-04-14 10:50:32.655498357 -0700
+++ VTK/Common/vtkSocket.h 2011-04-14 10:51:53.335704415 -0700
@@ -36,7 +36,7 @@
// Description:
// Close the socket.
- void CloseSocket() {this->CloseSocket(this->SocketDescriptor);}
+ void CloseSocket();
// ------ Communication API ---
// Description:
--- VTK/Common/vtkSocket.cxx 2011-02-27 13:47:42.787573794 -0800
+++ VTK/Common/vtkSocket.cxx 2011-02-27 14:00:30.506483646 -0800
@@ -16,6 +16,13 @@
#include "vtkObjectFactory.h"
+#include <algorithm>
+using std::max;
+#if defined(__BORLANDC__)
+# pragma warn -8012 /* signed/unsigned comparison */
+#endif
// The VTK_SOCKET_FAKE_API definition is given to the compiler
// command line by CMakeLists.txt if there is no real sockets
// interface available. When this macro is defined we simply make
@@ -38,25 +45,99 @@
#include <unistd.h>
#include <sys/time.h>
#include <errno.h>
+ #include <string.h>
+ #include <stdio.h>
#endif
#endif
#if defined(_WIN32) && !defined(__CYGWIN__)
+// TODO : document why we restrict to v1.1
#define WSA_VERSION MAKEWORD(1,1)
-#define vtkCloseSocketMacro(sock) (closesocket(sock))
-#else
-#define vtkCloseSocketMacro(sock) (close(sock))
-#endif
-#if defined(__BORLANDC__)
-# pragma warn -8012 /* signed/unsigned comparison */
+#define vtkCloseSocketMacro(sock) (closesocket(sock))
+#define vtkErrnoMacro (WSAGetLastError())
+#define vtkStrerrorMacro(_num) (wsaStrerror(_num))
+#define vtkSocketErrorIdMacro(_id) (WSA##_id)
+#define vtkSocketErrorReturnMacro (SOCKET_ERROR)
+#else
+#define vtkCloseSocketMacro(sock) (close(sock))
+#define vtkErrnoMacro (errno)
+#define vtkStrerrorMacro(_num) (strerror(_num))
+#define vtkSocketErrorIdMacro(_id) (_id)
+#define vtkSocketErrorReturnMacro (-1)
+#endif
+// This macro wraps a system function call(_call),
+// restarting the call in case it was interrupted
+// by a signal (EINTR).
+#define vtkRestartInterruptedSystemCallMacro(_call,_ret)\
+ do \
+ (_ret)=(_call); \
+ while (((_ret)==vtkSocketErrorReturnMacro) \
+ && (vtkErrnoMacro==vtkSocketErrorIdMacro(EINTR)));
+// use when _str may be a null pointer but _fallback is not.
+#define vtkSafeStrMacro(_str,_fallback) ((_str)?(_str):(_fallback))
+// convert error number to string and report via vtkErrorMacro.
+#define vtkSocketErrorMacro(_eno, _message) \
+ vtkErrorMacro( \
+ << (_message) \
+ << vtkSafeStrMacro( \
+ vtkStrerrorMacro(_eno), \
+ "unknown error") \
+// this pointer is not accessable in a static member function
+#define vtkGenericErrorMacro(x) \
+{ if (vtkObject::GetGlobalWarningDisplay()) { \
+ vtkOStreamWrapper::EndlType endl; \
+ vtkOStreamWrapper::UseEndl(endl); \
+ vtkOStrStreamWrapper vtkmsg; \
+ vtkmsg \
+ << "Error: In " __FILE__ ", line " \
+ << __LINE__ << "\n" x \
+ << "\n\n"; \
+ vtkOutputWindowDisplayErrorText(vtkmsg.str()); \
+ vtkmsg.rdbuf()->freeze(0);}}
+// convert error number to string and report via vtkGenericErrorMacro
+#define vtkSocketGenericErrorMacro(_message) \
+ vtkGenericErrorMacro( \
+ << (_message) \
+ vtkStrerrorMacro(vtkErrnoMacro), \
+// on windows sterror doesn't handle socket error codes
+#if defined(_WIN32) && !defined(__CYGWIN__)
+static
+const char *wsaStrerror(int wsaeid)
+ static char buf[256]={'\0'};
+ int ok;
+ ok=FormatMessage(FORMAT_MESSAGE_FROM_SYSTEM,0,wsaeid,0,buf,256,0);
+ if (!ok)
+ return 0;
+ return buf;
#endif
vtkSocket::vtkSocket()
this->SocketDescriptor = -1;
@@ -73,13 +154,26 @@
int vtkSocket::CreateSocket()
#ifndef VTK_SOCKET_FAKE_API
- int sock = socket(AF_INET, SOCK_STREAM, 0);
+ int sock;
+ vtkRestartInterruptedSystemCallMacro(socket(AF_INET,SOCK_STREAM, 0), sock);
+ if (sock == vtkSocketErrorReturnMacro)
+ vtkSocketErrorMacro(vtkErrnoMacro, "Socket error in call to socket.");
+ return -1;
// Elimate windows 0.2 second delay sending (buffering) data.
int on = 1;
- if (setsockopt(sock, IPPROTO_TCP, TCP_NODELAY, (char*)&on, sizeof(on)))
+ int iErr;
+ setsockopt(sock, IPPROTO_TCP, TCP_NODELAY, (char*)&on, sizeof(on)),
+ iErr);
+ if (iErr == vtkSocketErrorReturnMacro)
+ vtkSocketErrorMacro(vtkErrnoMacro, "Socket error in call to setsockopt.");
return -1;
return sock;
#else
return -1;
@@ -87,6 +181,13 @@
+void vtkSocket::CloseSocket()
+ this->CloseSocket(this->SocketDescriptor);
+ this->SocketDescriptor = -1;
int vtkSocket::BindSocket(int socketdescriptor, int port)
@@ -97,16 +198,31 @@
server.sin_port = htons(port);
// Allow the socket to be bound to an address that is already in use
int opt=1;
+ int iErr=~vtkSocketErrorReturnMacro;
#ifdef _WIN32
- setsockopt(socketdescriptor, SOL_SOCKET, SO_REUSEADDR, (char*) &opt, sizeof(int));
+ setsockopt(socketdescriptor,SOL_SOCKET,SO_REUSEADDR,(char*)&opt,sizeof(int)),
+ iErr);
#elif defined(VTK_HAVE_SO_REUSEADDR)
- setsockopt(socketdescriptor, SOL_SOCKET, SO_REUSEADDR, (void *) &opt, sizeof(int));
+ setsockopt(socketdescriptor,SOL_SOCKET,SO_REUSEADDR,(void*)&opt,sizeof(int)),
+ iErr);
#endif
+ return -1;
- if ( bind(socketdescriptor, reinterpret_cast<sockaddr*>(&server), sizeof(server)) )
+ bind(socketdescriptor,reinterpret_cast<sockaddr*>(&server),sizeof(server)),
+ iErr);
+ vtkSocketErrorMacro(vtkErrnoMacro, "Socket error in call to bind.");
return -1;
return 0;
#else
static_cast<void>(socketdescriptor);
@@ -121,9 +237,20 @@
if (socketdescriptor < 0)
+ vtkErrorMacro("Invalid descriptor.");
return -1;
- return accept(socketdescriptor, 0, 0);
+ int newDescriptor;
+ accept(socketdescriptor, 0, 0), newDescriptor);
+ if (newDescriptor == vtkSocketErrorReturnMacro)
+ vtkSocketErrorMacro(vtkErrnoMacro, "Socket error in call to accept.");
+ return -1;
+ return newDescriptor;
#else
return -1;
@@ -136,9 +263,19 @@
+ return -1;
+ int iErr;
+ vtkRestartInterruptedSystemCallMacro(listen(socketdescriptor, 1), iErr);
+ vtkSocketErrorMacro(vtkErrnoMacro, "Socket error in call to listen.");
return -1;
- return listen(socketdescriptor, 1);
+ return 0;
#else
return -1;
@@ -151,32 +288,54 @@
if (socketdescriptor < 0 )
- // invalid socket descriptor.
return -1;
fd_set rset;
- struct timeval tval;
- struct timeval* tvalptr = 0;
- if ( msec > 0 )
+ int res;
+ do
- tval.tv_sec = msec / 1000;
- tval.tv_usec = (msec % 1000)*1000;
- tvalptr = &tval;
+ struct timeval tval;
+ struct timeval* tvalptr = 0;
+ if (msec>0)
+ tval.tv_sec = msec / 1000;
+ tval.tv_usec = (msec % 1000)*1000;
+ tvalptr = &tval;
+ FD_ZERO(&rset);
+ FD_SET(socketdescriptor, &rset);
+ // block until socket is readable.
+ res = select(socketdescriptor+1, &rset, 0, 0, tvalptr);
- FD_ZERO(&rset);
- FD_SET(socketdescriptor, &rset);
- int res = select(socketdescriptor + 1, &rset, 0, 0, tvalptr);
- if(res == 0)
+ while ((res == vtkSocketErrorReturnMacro)
+ && (vtkErrnoMacro == vtkSocketErrorIdMacro(EINTR)));
+ if (res == 0)
- return 0;//for time limit expire
+ // time out
+ return 0;
- if ( res < 0 || !(FD_ISSET(socketdescriptor, &rset)) )
+ else
+ if (res == vtkSocketErrorReturnMacro)
- // Some error.
+ // error in the call
+ vtkSocketErrorMacro(vtkErrnoMacro, "Socket error in call to select.");
return -1;
+ else
+ if (!FD_ISSET(socketdescriptor, &rset))
+ vtkErrorMacro("Socket error in select. Descriptor not selected.");
+ return -1;
+ // NOTE: not checking for pending errors,these will be handled
+ // in the next call to read/recv
// The indicated socket has some activity on it.
return 1;
#else
@@ -191,50 +350,70 @@
unsigned long msec, int* selected_index)
- int i;
- int max_fd = -1;
*selected_index = -1;
- if (size < 0)
+ if (size < 0)
+ vtkGenericErrorMacro("Can't select fewer than 0.");
return -1;
fd_set rset;
- if ( msec > 0 )
- tval.tv_usec = msec % 1000;
- tvalptr = &tval;
- FD_ZERO(&rset);
- for (i=0; i<size; i++)
+ int res = -1;
+ do
- FD_SET(sockets_to_select[i],&rset);
- max_fd = (sockets_to_select[i] > max_fd)? sockets_to_select[i] : max_fd;
+ if (msec>0)
+ tval.tv_usec = msec % 1000;
+ tvalptr = &tval;
+ FD_ZERO(&rset);
+ int max_fd = -1;
+ for (int i=0; i<size; i++)
+ FD_SET(sockets_to_select[i],&rset);
+ max_fd = max(sockets_to_select[i],max_fd);
+ // block until one socket is ready to read.
+ res = select(max_fd + 1, &rset, 0, 0, tvalptr);
- int res = select(max_fd + 1, &rset, 0, 0, tvalptr);
- if (res == 0)
+ if (res==0)
- return 0; //Timeout
+ // time out
+ return 0;
- if (res < 0)
+ else
- // SelectSocket error.
+ vtkSocketGenericErrorMacro("Socket error in call to select.");
return -1;
- //check which socket has some activity.
+ // find the first socket which has some activity.
if ( FD_ISSET(sockets_to_select[i],&rset) )
+ // NOTE: not checking for pending errors, these
+ // will be handled in the next call to read/recv
*selected_index = i;
return 1;
+ // no activity on any of the sockets
+ vtkGenericErrorMacro("Socket error in select. No descriptor selected.");
return -1;
#else
static_cast<void>(sockets_to_select);
@@ -251,6 +430,7 @@
return -1;
@@ -261,10 +441,9 @@
unsigned long addr = inet_addr(hostName);
hp = gethostbyaddr((char *)&addr, sizeof(addr), AF_INET);
if (!hp)
- // vtkErrorMacro("Unknown host: " << hostName);
+ vtkErrorMacro("Unknown host: " << hostName);
return -1;
@@ -273,8 +452,48 @@
memcpy(&name.sin_addr, hp->h_addr, hp->h_length);
name.sin_port = htons(port);
- return connect(socketdescriptor, reinterpret_cast<sockaddr*>(&name),
- sizeof(name));
+ int iErr
+ = connect(socketdescriptor, reinterpret_cast<sockaddr*>(&name),sizeof(name));
+ if ( (iErr == vtkSocketErrorReturnMacro )
+ && (vtkErrnoMacro == vtkSocketErrorIdMacro(EINTR)) )
+ // Restarting an interrupted connect call only works on linux,
+ // other unix require a call to select which blocks until the
+ // connection is complete.
+ // See Stevens 2d ed, 15.4 p413, "interrupted connect"
+ iErr = this->SelectSocket(socketdescriptor,0);
+ if (iErr == -1)
+ // SelectSocket doesn't test for pending errors.
+ int pendingErr;
+ socklen_t pendingErrLen=sizeof(pendingErr);
+ getsockopt(socketdescriptor, SOL_SOCKET, SO_ERROR, &pendingErr, &pendingErrLen),
+ iErr);
+ vtkErrnoMacro, "Socket error in call to getsockopt.");
+ return -1;
+ else
+ if (pendingErr)
+ pendingErr, "Socket error pending from call to connect.");
+ return -1;
+ else
+ vtkErrnoMacro, "Socket error in call to connect.");
+ return -1;
+ return 0;
#else
static_cast<void>(hostName);
@@ -294,8 +513,14 @@
#else
int sizebuf = sizeof(sockinfo);
#endif
- if(getsockname(sock, reinterpret_cast<sockaddr*>(&sockinfo), &sizebuf) != 0)
+ int iErr;
+ getsockname(sock, reinterpret_cast<sockaddr*>(&sockinfo), &sizebuf),
+ iErr);
+ vtkErrnoMacro, "Socket error in call to getsockname.");
return 0;
return ntohs(sockinfo.sin_port);
@@ -311,9 +536,18 @@
return;
- vtkCloseSocketMacro(socketdescriptor);
+ int iErr;
+ vtkCloseSocketMacro(socketdescriptor),
+ iErr);
+ vtkErrnoMacro, "Socket error in call to close/closesocket.");
#else
return;
@@ -326,6 +560,7 @@
if (!this->GetConnected())
+ vtkErrorMacro("Not connected.");
return 0;
if (length == 0)
@@ -337,22 +572,19 @@
int total = 0;
do
- int flags;
-#if defined(_WIN32) && !defined(__CYGWIN__)
- flags = 0;
-#else
- // disabling, since not present on SUN.
- // flags = MSG_NOSIGNAL; //disable signal on Unix boxes.
- flags = 0;
-#endif
- int n = send(this->SocketDescriptor, buffer+total, length-total, flags);
- if(n < 0)
+ int flags=0;
+ int nSent;
+ send(this->SocketDescriptor, buffer+total, length-total, flags),
+ nSent);
+ if (nSent == vtkSocketErrorReturnMacro)
- vtkErrorMacro("Socket Error: Send failed.");
+ vtkSocketErrorMacro(vtkErrnoMacro, "Socket error in call to send.");
return 0;
- total += n;
+ total += nSent;
} while(total < length);
return 1;
#else
static_cast<void>(data);
@@ -367,39 +599,49 @@
return 0;
+ int trys = 0;
+#endif
char* buffer = reinterpret_cast<char*>(data);
int total = 0;
do
- int trys = 0;
-#endif
- int n = recv(this->SocketDescriptor, buffer+total, length-total, 0);
- if(n < 1)
+ int nRecvd;
+ recv(this->SocketDescriptor, buffer+total, length-total, 0),
+ nRecvd);
+ if (nRecvd == 0)
+ // peer shut down
+ return 0;
+ if ((nRecvd == vtkSocketErrorReturnMacro)
+ && (WSAGetLastError() == WSAENOBUFS))
// On long messages, Windows recv sometimes fails with WSAENOBUFS, but
// will work if you try again.
- int error = WSAGetLastError();
- if ((error == WSAENOBUFS) && (trys++ < 1000))
+ if ((trys++ < 1000))
Sleep(1);
continue;
-#else
- // On unix, a recv may be interrupted by a signal. In this case we should
- // retry.
- int errorNumber = errno;
- if (errorNumber == EINTR) continue;
-#endif
- vtkErrorMacro("Socket Error: Receive failed.");
+ vtkSocketErrorMacro(vtkErrnoMacro, "Socket error in call to recv.");
return 0;
- total += n;
- } while(readFully && total < length);
+#endif
+ total += nRecvd;
+ while( readFully && (total < length));
return total;
#else
