| 0011738 | ParaView | Bug | public | 2011-01-20 21:46 | 2011-07-19 20:03 | ||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Status | closed | Resolution | unable to reproduce | ||||||
| Product Version | |||||||||
| Target Version | Someday | Fixed in Version | |||||||
| Summary | 0011738: Viewport size is wrong | ||||||||
| Description | I am seeing a really strange viewport clear bug. I will attach a screenshot. This occurs more often with the normal glyph filter, but seems to happen all of the time, in a harder to replicate pattern. I have two monitors on my computer, the main one is the bigger one. * ParaView trunk, remote server (doesn't have problems local server), Windows client (probably needs to be Windows 7). * On Windows 7, start ParaView in the larger monitor. Click the <windows key> + <left arrow>. This has now placed ParaView in the left half of the window. * Open disk_out_ref.exo. Apply. * Normals Glpyhs filter. Apply. * Move disk_out_ref.exo towards the bottom of the 3d window (<SHFT>, <right arrow>). * Rotate. You should see that the bottom of the window has bad frame buffer junk. Thinking about it, this could very likely be a driver issue. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0026467) Utkarsh Ayachit (administrator) 2011-05-09 10:51 |
Alan, please reopen if you can still reproduce this. Also did you forget to attach the screenshot? |
(0027029) Alan Scott (manager) 2011-07-19 20:03 |
I tried, and couldn't replicate this on trunk. |
| Notes |
| Issue History | |||
| 2011-01-20 21:46 | Alan Scott | New Issue | |
| 2011-05-09 10:51 | Utkarsh Ayachit | Note Added: 0026467 | |
| 2011-05-09 10:51 | Utkarsh Ayachit | Status | backlog => @80@ |
| 2011-05-09 10:51 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
| 2011-05-09 10:51 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2011-07-19 20:03 | Alan Scott | Note Added: 0027029 | |
| 2011-07-19 20:03 | Alan Scott | Status | customer review => closed |
| Issue History |
