| 0011697 | ParaView | Bug | public | 2011-01-14 10:30 | 2012-02-08 17:24 | ||||
| Reporter | Paul Edwards | ||||||||
| Assigned To | Kyle Lutz | ||||||||
| Priority | normal | Severity | major | Reproducibility | always | ||||
| Product Version | Development | ||||||||
| Target Version | 3.12 | Fixed in Version | 3.12 | ||||||
| Summary | 0011697: All points are converted to floating point when run through D3 | ||||||||
| Description | The points datatype is always float regardless of the datatype going in. | ||||||||
| Steps To Reproduce | Run attached script. Output: 8<----------------------------------------------------------------- paul@localhost:~/d3test$ pvpython d3-bug-double-precision-points-lost.py Listen on port: 11111 Waiting for client... Client connected. vtkSphereSource : [ ...........] vtkSphereSource(1) : [ ...........] vtkSphereSource : [ ...........] Process id: 0 >> Datatype is 11 Process id: 1 >> Datatype is 11 vtkPythonProgrammableFilter(1) : [ ...........] vtkDistributedDataFilter(1) : [ ...........] Clean up and finish : [ ...........] vtkPythonProgrammableFilter(1) : [ ...........] Process id: 0 >> Datatype is 10 Process id: 1 >> Datatype is 10 paul@localhost:~/d3test$ ----------------------------------------------------------------->8 | ||||||||
| Additional Information | Additional point data will stay the same type - it is only for the coordinates. | ||||||||
| Project | TBD | ||||||||
| Topic Name | 11697-fix-d3-data-type | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0027453) Paul Edwards (reporter) 2011-09-05 05:56 |
I just realised I didn't add the python test. I have also added a patch to fix the issue. |
(0027454) Kyle Lutz (viewer) 2011-09-05 10:23 |
Merge topic '11697-fix-d3-data-type' into pv-next 9aa84ed Perserve original data type in D3 filter Merge topic '11697-fix-d3-data-type' into next f54995e Update VTK to bring in '11697-fix-d3-data-type' |
(0027455) Kyle Lutz (viewer) 2011-09-05 10:24 |
Test output with patch applied: $ ./pvpython /home/kyle/Downloads/d3-bug-double-precision-points-lost.py Waiting for client Connection URL: cs://localhost:11111 Client connected. Datatype is 11 Datatype is 11 Datatype is 11 Datatype is 11 Exiting... Exiting... |
(0027467) Utkarsh Ayachit (administrator) 2011-09-09 14:14 |
merged into git-master. |
(0028143) Utkarsh Ayachit (administrator) 2012-02-08 17:24 |
Closing bugs sitting in "customer review" for a long time. |
| Notes |
| Issue History | |||
| 2011-01-14 10:30 | Paul Edwards | New Issue | |
| 2011-01-20 09:39 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2011-01-20 09:39 | Utkarsh Ayachit | Status | backlog => tabled |
| 2011-09-05 05:54 | Paul Edwards | File Added: d3-bug-double-precision-points-lost.py | |
| 2011-09-05 05:55 | Paul Edwards | File Added: d3-bug-double-precision-points-lost.patch | |
| 2011-09-05 05:56 | Paul Edwards | Note Added: 0027453 | |
| 2011-09-05 10:16 | Kyle Lutz | Assigned To | Utkarsh Ayachit => Kyle Lutz |
| 2011-09-05 10:16 | Kyle Lutz | Status | backlog => todo |
| 2011-09-05 10:16 | Kyle Lutz | Status | todo => active development |
| 2011-09-05 10:23 | Kyle Lutz | Topic Name | => 11697-fix-d3-data-type |
| 2011-09-05 10:23 | Kyle Lutz | Note Added: 0027454 | |
| 2011-09-05 10:23 | Kyle Lutz | Status | active development => gatekeeper review |
| 2011-09-05 10:23 | Kyle Lutz | Resolution | open => fixed |
| 2011-09-05 10:24 | Kyle Lutz | Note Added: 0027455 | |
| 2011-09-06 09:07 | Utkarsh Ayachit | Project | => TBD |
| 2011-09-06 09:07 | Utkarsh Ayachit | Type | => incorrect functionality |
| 2011-09-06 09:07 | Utkarsh Ayachit | Target Version | => 3.12 |
| 2011-09-09 14:13 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2011-09-09 14:14 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2011-09-09 14:14 | Utkarsh Ayachit | Note Added: 0027467 | |
| 2011-11-11 17:03 | Utkarsh Ayachit | Fixed in Version | git-master => 3.12 |
| 2012-02-08 17:24 | Utkarsh Ayachit | Status | customer review => closed |
| 2012-02-08 17:24 | Utkarsh Ayachit | Note Added: 0028143 | |
| Issue History |
