| 0011686 | ParaView | Bug | public | 2011-01-12 06:18 | 2011-09-01 13:31 | ||||
| Reporter | Paul Edwards | ||||||||
| Assigned To | Andy Bauer | ||||||||
| Priority | normal | Severity | major | Reproducibility | always | ||||
| Platform | Linux | OS | Ubuntu | OS Version | 10.04 | ||||
| Product Version | Development | ||||||||
| Target Version | Fixed in Version | 3.12 | |||||||
| Summary | 0011686: D3 crashes when points are stored double precision and ghost cells are on | ||||||||
| Description | This only happens when points are stored as double precision and ghost cells are required. | ||||||||
| Steps To Reproduce | This Python extract demonstrates the problem (you will need to start you parallel server and connect to it at the top): 8<--------------------------------------------------- # connect to the parallel server (2 procs are enough) Sphere1 = Sphere( guiName="Sphere1", EndTheta=360.0, Center=[0.0, 0.0, 0.0], StartTheta=0.0, PhiResolution=38, Radius=0.5, ThetaResolution=38, EndPhi=180.0, StartPhi=0.0 ) ProgrammableFilter3 = ProgrammableFilter( guiName="ProgrammableFilter3", OutputDataSetType='Same as Input', RequestInformationScript='', Script='pdi = self.GetPolyDataInput()\npdo = self.GetPolyDataOutput()\nnewPoints = vtk.vtkPoints()\nnewPoints.SetDataTypeToDouble()\nnumPoints = pdi.GetNumberOfPoints()\nfor i in range(0, numPoints):\n coord = pdi.GetPoint(i)\n x, y, z = coord[:3]\n x = x * 1\n y = y * 1.3\n z = z * 0.3\n newPoints.InsertPoint(i, x, y, z)\npdo.SetPoints(newPoints)', PythonPath='', CopyArrays=0 ) D32 = D3( guiName="D32", BoundaryMode='Duplicate cells', MinimalMemory=0 ) ProcessIdScalars3 = ProcessIdScalars( guiName="ProcessIdScalars3", RandomMode=0 ) Show() Render() # this works ExtractSurface2 = ExtractSurface( guiName="ExtractSurface2", NonlinearSubdivisionLevel=1, PieceInvariant=1 ) Show() # now that ghost cells are required and D3 is rerun it crashes --------------------------------------------------->8 | ||||||||
| Additional Information | In GetGhostPointIds the local variable called processId is getting set to -1 and then used to index an array. On lines 3752 & 3753 is where this happens: regionId = kd->GetRegionContainingPoint(pt[0], pt[1], pt[2]); processId = kd->GetProcessAssignedToRegion(regionId); The point might be outside due to rounding a double to a float at some point? It is very close to an actual point. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0024622) Andy Bauer (developer) 2011-01-12 11:13 |
I tried it out on my machine and didn't encounter any problems. I'm using the latest version of ParaView checked out on 1/12/11. What version of ParaView are you using? Can you try updating ParaView and see if you're still getting the problem since I'm not sure how I'm going to reproduce it otherwise? If it still isn't working for you, let me know the details of your machine, compilers, ParaView SHA, etc. |
(0024624) Andy Bauer (developer) 2011-01-12 11:14 |
Sorry, I had a typo in the programmable filter that I didn't notice. I'm able to trigger the problem. |
(0024639) Andy Bauer (developer) 2011-01-12 20:48 |
It was a problem in vtkPKdTree. I fixed it by expanding the bounding box slightly. It will take a couple of days before it filters up to paraview and for me to check that it works properly everywhere. I'll mark it as resolved when this happens. |
(0024641) Paul Edwards (reporter) 2011-01-13 05:33 |
Thanks - I've applied the patch and it is working for me. |
(0024679) Andy Bauer (developer) 2011-01-14 11:18 |
ParaView's VTK SHA is now updated to include the fix so this should work properly now. Paul, please close this issue if everything is working fine for you. |
(0025413) Alan Scott (manager) 2011-02-11 21:45 |
Developer and reporter say it is fixed. Closing. |
| Notes |
| Issue History | |||
| 2011-01-12 06:18 | Paul Edwards | New Issue | |
| 2011-01-12 11:09 | Andy Bauer | Assigned To | => Andy Bauer |
| 2011-01-12 11:09 | Andy Bauer | Status | backlog => tabled |
| 2011-01-12 11:13 | Andy Bauer | Note Added: 0024622 | |
| 2011-01-12 11:13 | Andy Bauer | Status | tabled => @20@ |
| 2011-01-12 11:14 | Andy Bauer | Note Added: 0024624 | |
| 2011-01-12 11:14 | Andy Bauer | Status | @20@ => @40@ |
| 2011-01-12 20:48 | Andy Bauer | Note Added: 0024639 | |
| 2011-01-13 05:33 | Paul Edwards | Note Added: 0024641 | |
| 2011-01-14 11:18 | Andy Bauer | Note Added: 0024679 | |
| 2011-01-14 11:18 | Andy Bauer | Status | @40@ => @80@ |
| 2011-01-14 11:18 | Andy Bauer | Fixed in Version | => Development |
| 2011-01-14 11:18 | Andy Bauer | Resolution | open => fixed |
| 2011-02-11 21:45 | Alan Scott | Note Added: 0025413 | |
| 2011-02-11 21:45 | Alan Scott | Status | @80@ => closed |
| 2011-09-01 13:31 | Utkarsh Ayachit | Fixed in Version | Development => 3.12 |
| Issue History |
