| 0011233 | ParaView | Bug | public | 2010-09-14 16:37 | 2016-07-13 15:47 | ||||
| Assigned To | Alan Scott | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Product Version | |||||||||
| Target Version | WhenPossible | Fixed in Version | |||||||
| Summary | 0011233: Point Sprite does not follow color by properly | ||||||||
| Description | ParaView 3.8.1 RC1, Linux, remote server. Open can.exo. All variables on. Apply. (Should come up in Surface rendering.) Color by EQPS. Turn the color legend on. Point Sprite. * Note that the EQPS still shows, and if you open the color editor, it looks like it is for EQPS, but the Point Sprite shows as "Solid Color" It should probably track everything else. Otherwise, the color editor and color legend should act like we are showing a "Solid Color". Marking high since it can mis-represent data. It really should be marked medium-high, since I don't know how often Point Sprites are used. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0036409) Alan Scott (manager) 2016-07-13 15:47 |
Point sprite no longer exists. Closing bug. |
| Notes |
| Issue History | |||
| 2010-09-14 16:37 | Alan Scott | New Issue | |
| 2010-11-05 13:39 | Utkarsh Ayachit | Priority | high => normal |
| 2010-11-05 13:39 | Utkarsh Ayachit | Target Version | 3.10 => WhenPossible |
| 2016-07-13 15:47 | Alan Scott | Note Added: 0036409 | |
| 2016-07-13 15:47 | Alan Scott | Status | expired => closed |
| 2016-07-13 15:47 | Alan Scott | Assigned To | => Alan Scott |
| 2016-07-13 15:47 | Alan Scott | Resolution | open => fixed |
| Issue History |
