| Attached Files | procOrphans.patch [^] (9,329 bytes) 2010-02-12 17:49 [Show Content] [Hide Content]Index: Qt/Core/pqCommandServerStartup.h
RCS file: /cvsroot/ParaView3/ParaView3/Qt/Core/pqCommandServerStartup.h,v
retrieving revision 1.11
diff -u -r1.11 pqCommandServerStartup.h
--- Qt/Core/pqCommandServerStartup.h 4 Apr 2008 13:31:57 -0000 1.11
+++ Qt/Core/pqCommandServerStartup.h 12 Feb 2010 21:47:46 -0000
@@ -41,6 +41,8 @@
#include <QPointer>
#include <QTimer>
+class pqServer;
// pqCommandServerStartup
@@ -56,11 +58,13 @@
const pqServerResource& server,
bool shouldSave,
vtkPVXMLElement* configuration);
+ ~pqCommandServerStartup();
+ void cleanUpProcess();
const QString getName();
- const pqServerResource getServer();
+ const pqServerResource getServer();
vtkPVXMLElement* getConfiguration();
void execute(const OptionsT& options);
const QString getExecutable();
@@ -74,12 +78,16 @@
void onStarted();
void onError(QProcess::ProcessError error);
void onDelayComplete();
+ void onProcessFinished(){ this->cleanUpProcess(); }
+ void onServerConnect(pqServer *server);
+ void onServerDisconnect(pqServer *server);
private:
const QString Name;
- const pqServerResource Server;
+ const pqServerResource ServerResource;
vtkSmartPointer<vtkPVXMLElement> Configuration;
- QPointer<QProcess> Process;
+ QProcess *Process;
+ pqServer *Server;
QTimer Timer;
Index: Qt/Core/pqCommandServerStartup.cxx
RCS file: /cvsroot/ParaView3/ParaView3/Qt/Core/pqCommandServerStartup.cxx,v
retrieving revision 1.21
diff -u -r1.21 pqCommandServerStartup.cxx
--- Qt/Core/pqCommandServerStartup.cxx 30 Sep 2009 19:16:02 -0000 1.21
+++ Qt/Core/pqCommandServerStartup.cxx 12 Feb 2010 21:47:47 -0000
@@ -44,6 +44,9 @@
#include "vtkPVXMLElement.h"
#include "pqServerResource.h"
+#include "pqServer.h"
+#include "pqApplicationCore.h"
+#include "pqServerManagerModel.h"
class pqCommandServerStartupWSAInit
@@ -81,15 +84,70 @@
const QString& name,
bool save,
- vtkPVXMLElement* configuration) :
+ vtkPVXMLElement* configuration)
pqServerStartup(save),
Name(name),
- Server(server.schemeHostsPorts()),
+ ServerResource(server.schemeHostsPorts()),
Configuration(configuration),
- Process(NULL)
+ Process(NULL),
+ Server(NULL)
+pqCommandServerStartup::~pqCommandServerStartup()
+ this->cleanUpProcess();
+void pqCommandServerStartup::cleanUpProcess()
+ if (this->Process)
+ // We're about to close the process, we should stop resonding
+ // to its signals and on its behalf.
+ pqServerManagerModel *smm
+ = pqApplicationCore::instance()->getServerManagerModel();
+ QObject::disconnect(
+ smm,SIGNAL(serverAdded(pqServer *)),
+ this, SLOT(onServerConnect(pqServer *)));
+ smm,SIGNAL(serverRemoved(pqServer *)),
+ this, SLOT(onServerDisconnect(pqServer *)));
+ this->Process, SIGNAL(readyReadStandardError()),
+ this, SLOT(onReadyReadStandardError()));
+ this->Process, SIGNAL(readyReadStandardOutput()),
+ this, SLOT(onReadyReadStandardOutput()));
+ this->Process, SIGNAL(error(QProcess::ProcessError)),
+ this, SLOT(onError(QProcess::ProcessError)));
+ this->Process, SIGNAL(started()),
+ this, SLOT(onStarted()));
+ &this->Timer, SIGNAL(timeout()),
+ this, SLOT(onDelayComplete()));
+ // close running process
+ if (this->Process->state()==QProcess::Running)
+ this->Process->close();
+ // free the object
+ delete this->Process;
+ this->Process=NULL;
+ // mark the object as unassociated.
+ this->Server=NULL;
const QString pqCommandServerStartup::getName()
return this->Name;
@@ -97,7 +155,7 @@
const pqServerResource pqCommandServerStartup::getServer()
- return this->Server;
+ return this->ServerResource;
vtkPVXMLElement* pqCommandServerStartup::getConfiguration()
@@ -110,32 +168,32 @@
// Generate predefined variables ...
OptionsT options;
options["PV_CONNECTION_URI"] =
- this->Server.toURI();
+ this->ServerResource.toURI();
options["PV_CONNECTION_SCHEME"] =
- this->Server.scheme();
+ this->ServerResource.scheme();
options["PV_CLIENT_HOST"] =
localHostName();
options["PV_SERVER_HOST"] =
- this->Server.host();
+ this->ServerResource.host();
options["PV_SERVER_PORT"] =
- QString::number(this->Server.port(11111));
+ QString::number(this->ServerResource.port(11111));
options["PV_DATA_SERVER_HOST"] =
- this->Server.dataServerHost();
+ this->ServerResource.dataServerHost();
options["PV_DATA_SERVER_PORT"] =
- QString::number(this->Server.dataServerPort(11111));
+ QString::number(this->ServerResource.dataServerPort(11111));
options["PV_RENDER_SERVER_HOST"] =
- this->Server.renderServerHost();
+ this->ServerResource.renderServerHost();
options["PV_RENDER_SERVER_PORT"] =
- QString::number(this->Server.renderServerPort(22221));
+ QString::number(this->ServerResource.renderServerPort(22221));
options["PV_CONNECT_ID"] = "";
options["PV_USERNAME"] = ""; // Unused at the moment
// Merge user variables, allowing user variables to "override" the predefined variables ...
for(OptionsT::const_iterator option = user_options.begin(); option != user_options.end(); ++option)
const QString key = option.key();
const QString value = option.value();
options.erase(options.find(key));
options.insert(key, value);
@@ -149,7 +207,7 @@
environment.push_back(option.key() + "=" + option.value());
// Setup the process arguments ...
QString executable = this->getExecutable();
// const double timeout = this->getTimeout();
@@ -176,7 +234,7 @@
const QString after = options[variable];
argument.replace(before, after);
if(argument.isEmpty())
i = arguments.erase(i);
@@ -187,32 +245,45 @@
this->Process = new QProcess;
- QObject::connect(this->Process, SIGNAL(finished(int, QProcess::ExitStatus)),
- this->Process, SLOT(deleteLater()));
+ // set up connections to learn about which server is
+ // created/destroyed.
+ QObject::connect(
+ QObject::connect(
this->Process->setEnvironment(environment);
QObject::connect(
QObject::connect(
QObject::connect(
+ // After some ellapsed time examine the newly created process
+ // to determine if we have successfully connected or if something
+ // else has happened. Will write a report to the terminal.
QObject::connect(
QObject::connect(
this->Process->start(executable, arguments);
@@ -229,14 +300,14 @@
result = xml_command->GetAttribute("exec");
return result;
double pqCommandServerStartup::getTimeout()
double result = 0.0;
vtkPVXMLElement* xml = this->Configuration;
if(QString(xml->GetName()) == "CommandStartup")
@@ -246,14 +317,14 @@
result = QString(xml_command->GetAttribute("timeout")).toDouble();
return result;
double pqCommandServerStartup::getDelay()
@@ -263,7 +334,7 @@
result = QString(xml_command->GetAttribute("delay")).toDouble();
return result;
@@ -296,7 +367,7 @@
return results;
@@ -334,7 +405,7 @@
break;
this->Timer.stop();
emit this->failed();
@@ -351,3 +422,22 @@
emit this->succeeded();
+void pqCommandServerStartup::onServerConnect(pqServer *server)
+ // make this a one time occurance per process.
+ if (this->Process && this->Server==NULL)
+ // save the server id so we can identify our server during
+ // server remove events
+ this->Server=server;
+void pqCommandServerStartup::onServerDisconnect(pqServer *server)
+ // only react to our server's events
+ if (server==this->Server)
