lib64
cmake
paraview-5.9
vtk
vtkTestingRenderingDriver.cmake
1
SET(CMAKE_TESTDRIVER_BEFORE_TESTMAIN
3
vtksys::SystemInformation::SetStackTraceOnError(1);
4
#ifndef NDEBUG
5
vtkFloatingPointExceptions::Enable();
6
#endif
7
// Set defaults
9
vtkTestingInteractor::ValidBaseline = \"Use_-V_for_Baseline\";
10
vtkTestingInteractor::TempDirectory =
11
std::string(\"${_vtk_build_TEST_OUTPUT_DIRECTORY}\");
12
vtkTestingInteractor::DataDirectory = std::string(\"Use_-D_for_Data\");
13
14
int interactive = 0;
15
for (int ii = 0; ii < ac; ++ii)
16
17
if (strcmp(av[ii], \"-I\") == 0)
18
interactive = 1;
20
continue;
21
22
if (ii < ac-1 && strcmp(av[ii], \"-V\") == 0)
23
24
vtkTestingInteractor::ValidBaseline = std::string(av[++ii]);
25
continue;
26
27
if (ii < ac-1 && strcmp(av[ii], \"-T\") == 0)
28
vtkTestingInteractor::TempDirectory = std::string(av[++ii]);
30
continue;
31
32
if (ii < ac-1 && strcmp(av[ii], \"-D\") == 0)
33
vtkTestingInteractor::DataDirectory = std::string(av[++ii]);
35
continue;
36
37
if (ii < ac-1 && strcmp(av[ii], \"-E\") == 0)
38
vtkTestingInteractor::ErrorThreshold =
40
static_cast<double>(atof(av[++ii]));
41
continue;
42
43
if (ii < ac-1 && strcmp(av[ii], \"-v\") == 0)
45
vtkLogger::SetStderrVerbosity(static_cast<vtkLogger::Verbosity>(atoi(av[++ii])));
46
continue;
47
48
49
50
// init logging
51
vtkLogger::Init(ac, av, nullptr);
52
53
// turn on windows stack traces if applicable
54
vtkWindowsTestUtilitiesSetupForTesting();
55
56
vtkSmartPointer<vtkTestingObjectFactory> factory = vtkSmartPointer<vtkTestingObjectFactory>::New();
57
if (!interactive)
58
59
// Disable any other overrides before registering our factory.
60
vtkObjectFactoryCollection *collection = vtkObjectFactory::GetRegisteredFactories();
61
collection->InitTraversal();
62
vtkObjectFactory *f = collection->GetNextItem();
63
while (f)
64
65
f->Disable(\"vtkRenderWindowInteractor\");
66
67
68
vtkObjectFactory::RegisterFactory(factory);
69
70
71
72
73
SET(CMAKE_TESTDRIVER_AFTER_TESTMAIN
74
75
if (result == VTK_SKIP_RETURN_CODE)
76
77
printf(\"Unsupported runtime configuration: Test returned \"
78
\"VTK_SKIP_RETURN_CODE. Skipping test.\\n\");
79
return result;
80
81
82
if (!interactive)
83
84
if (vtkTestingInteractor::TestReturnStatus != -1)
85
86
if (vtkTestingInteractor::TestReturnStatus != vtkTesting::PASSED)
87
88
result = EXIT_FAILURE;
89
90
else
91
92
result = EXIT_SUCCESS;
93
94
95
vtkObjectFactory::UnRegisterFactory(factory);
96
97
98
