| std::string & | vtkGenericIOUtilities::trim (std::string &s) |
| | Trims leading & trailing whitespace from a string. More...
| MPI_Comm | vtkGenericIOUtilities::GetMPICommunicator (vtkMultiProcessController *mpc) |
| | Returns the corresponding MPI communicator for the multi-process controller used by this instance. More...
| vtkDataArray * | vtkGenericIOUtilities::GetVtkDataArray (std::string name, int type, void *rawBuffer, int N) |
| | This method parses the data in the rawbuffer and reads it into a vtkDataArray that can be attached as vtkPointData to a vtkDataSet, in this case, a vtkUnstructuredGrid that consists of the particles. More...
| vtkIdType | vtkGenericIOUtilities::GetIdFromRawBuffer (const int type, void *buffer, vtkIdType buffer_idx) |
| | This method accesses the user-supplied buffer at the given index and returns the data as a vtkIdType. More...
| double | vtkGenericIOUtilities::GetDoubleFromRawBuffer (const int type, void *buffer, vtkIdType buffer_idx) |
| | This method accesses the user-supplied buffer at the given index and returns the data as a double. More...
| gio::GenericIOReader * | vtkGenericIOUtilities::GetReader (MPI_Comm comm, bool posix, int distribution, const std::string &fileName) |
| | This method constructs and returns the underlying GenericIO reader. More...
| gio::GenericIOWriter * | vtkGenericIOUtilities::GetWriter (MPI_Comm comm, const std::string &fileName) |
| | This method constructs and returns the underlying GenericIO writer. More...
| std::string & | vtkGenericIOUtilities::ltrim (std::string &s) |
| | Trims leading whitespace from a string. More...
| std::string & | vtkGenericIOUtilities::rtrim (std::string &s) |
| | Trims trailing whitespace from a string. More...
| void | vtkGenericIOUtilities::SafeDeleteString (char *&str) |
| | If the pointer given is non-null this function deletes the string and set the pointer to NULL. More...
