3 if(
4 message(FATAL_ERROR
"CMake >= 2.6.0 required")
15 if(CMAKE_VERSION VERSION_LESS 3.0.0)
16 message(FATAL_ERROR
"This file relies on consumers using CMake 3.0.0 or greater.")
19 # Protect against multiple inclusion, which would fail when already imported targets are added once more. 21 set(_targetsNotDefined)
23 foreach(_expectedTarget ParaView::paraview_plugins)
24 list(APPEND _expectedTargets ${_expectedTarget})
25 if(NOT TARGET ${_expectedTarget})
26 list(APPEND _targetsNotDefined ${_expectedTarget})
28 if(TARGET ${_expectedTarget})
29 list(APPEND _targetsDefined ${_expectedTarget})
32 if("${_targetsDefined}
") 33 unset(_targetsDefined) 34 unset(_targetsNotDefined) 35 unset(_expectedTargets) 36 set(CMAKE_IMPORT_FILE_VERSION) 40 if(NOT "${_targetsDefined}
" STREQUAL "") 41 message(FATAL_ERROR "Some (but not all) targets in
this export
") 43 unset(_targetsDefined) 44 unset(_targetsNotDefined) 45 unset(_expectedTargets) 48 # Create imported target ParaView::paraview_plugins 49 add_library(ParaView::paraview_plugins INTERFACE IMPORTED) 51 set_target_properties(ParaView::paraview_plugins PROPERTIES 52 INTERFACE_INCLUDE_DIRECTORIES "/home/paraview/build/CMakeFiles/ParaView_paraview_plugins
" 55 # This file does not depend on other imported targets which have 56 # been exported from the same project but in a separate export set. 58 # Commands beyond this point should not need to know the version. 59 set(CMAKE_IMPORT_FILE_VERSION)
