3 This page describes how to build and install ParaView. It covers building for
4 development, on both Unix-type systems (Linux, HP-UX, Solaris, macOS), and
5 Windows. Note that Unix-like environments such as Cygwin and MinGW are not
6 officially supported. However, patches to fix problems with these platforms
7 will be considered for inclusion.
9 ParaView depends on several open source tools and libraries such as Python, Qt,
10 CGNS, HDF5, etc. Some of these are included in the ParaView source itself
11 (e.g., HDF5), while others are expected to be present on the machine on which
12 ParaView is being built (e.g., Python, Qt).
14 The first chapter is a getting started guide by OS that is very helpful if you have never
15 built ParaView before and do not know which options you need.
16 If you are looking for the generic help, please read the [Complete Compilation Guide](#complete-compilation-guide)
18 ## Getting Started Guide
19 This is a section intended to help those that have never built ParaView before, are not
20 experienced with compilation in general or have no idea which option they may need when building ParaView.
21 If you follow this guide, you will be able to compile and run a standard version of ParaView
22 for your operating system. It will be built with the python wrapping, MPI capabilities and multithread capabilities.
24 * If you are using a Linux distribution, please see [the Linux part](#linux),
25 * If you are using Microsoft Windows, please see [the Windows part](#windows),
26 * If you are using another OS, feel free to provide compilation steps.
31 Please run the command in a terminal to install the following dependencies depending of your linux distribution.
33 ##### Ubuntu 18.04 LTS / Debian 10
34 `sudo apt-get install git cmake build-essential libgl1-mesa-dev libxt-dev qt5-default libqt5x11extras5-dev libqt5help5 qttools5-dev qtxmlpatterns5-dev-tools libqt5svg5-dev python3-dev python3-numpy libopenmpi-dev libtbb-dev ninja-build`
39 Download and install [cmake][cmake-download]) as the packaged version is not enough considering that
40 CMake 3.12 or higher is needed.
43 `sudo yum install python3-devel openmpi-devel mesa-libGL-devel libX11-devel libXt-devel qt5-qtbase-devel qt5-qtx11extras-devel qt5-qttools-devel qt5-qtxmlpatterns-devel tbb-devel ninja-build git`
47 alias ninja=ninja-build
48 export PATH=$PATH:/usr/lib64/openmpi/bin/
52 `sudo pacman -S base-devel ninja openmpi tbb qt python python-numpy cmake`
54 ##### Other distribution
55 If you are using another distribution, please try to adapt the package list.
56 Feel free to then provide it so we can integrate it in this guide by creating an [issue][paraview-issues].
60 To build ParaView developement version (usually refered as "master"), please run the following commands in a terminal :
62 git clone --recursive https://gitlab.kitware.com/paraview/paraview.git
65 cmake -GNinja -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_MPI=ON -DVTK_SMP_IMPLEMENTATION_TYPE=TBB -DCMAKE_BUILD_TYPE=Release ../paraview
69 To build a specific ParaView version, eg: v5.6.0 , please run the following commands in a terminal while replacing "tag" by the version you want to build
71 git clone https://gitlab.kitware.com/paraview/paraview.git
75 git submodule update --init --recursive
77 cmake -GNinja -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_MPI=ON -DVTK_SMP_IMPLEMENTATION_TYPE=TBB -DCMAKE_BUILD_TYPE=Release ../paraview
82 Double click on the paraview executable in the bin directory or run in the previous terminal
90 Note: the following steps concerning Visual Studio 2015 can also be applied to Visual Studio 2019.
91 If so, beware to use the msvc2019_64 Qt Version and the Developer Command Prompt for VS 2019.
94 * Download and install [git bash for windows][gitforwindows]
95 * Download and install [cmake][cmake-download]
96 * Download and install [Visual Studio 2015 Community Edition][visual-studio]
97 * Download [ninja-build][ninja] and drop `ninja.exe` in `C:\Windows\`
98 * Download and install both `msmpisetup.exe` and `msmpisdk.msi` from [Microsoft MPI][msmpi]
99 * Download and install [Python for windows][pythonwindows], make sure to add the path to your Python installation folder to the `PATH` environnement variable.
100 * Download and install [Qt 5.12.3][qt-download-5.12.3] for windows, make sure to check the MSVC 2015 64-bit component during installation, make sure to add `C:\Qt\Qt5.12.3\5.12.3\msvc2015_64\bin` to your `PATH` environnement variable.
102 #### Recover the source
104 * To build ParaView developement version (usually refered as "master"), run the following commands:
110 git clone --recursive https://gitlab.kitware.com/paraview/paraview.git
115 * Or, to build a specific ParaView version, eg: v5.6.0 , please run the following commands while replacing "tag" by the version you want to build
121 git clone https://gitlab.kitware.com/paraview/paraview.git
126 git submodule update --init --recursive
131 * Open VS2015 x64 Native Tools Command Prompt and run the following commands
134 cmake -GNinja -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_MPI=ON -DVTK_SMP_IMPLEMENTATION_TYPE=OpenMP -DCMAKE_BUILD_TYPE=Release ..\pv
140 * Double click on the `C:\pv\pvb\bin\paraview` executable
142 ## Complete Compilation Guide
144 ### Obtaining the source
146 To obtain ParaView's sources locally, clone this repository using
150 git clone --recursive https://gitlab.kitware.com/paraview/paraview.git
155 ParaView supports all of the common generators supported by CMake. The Ninja,
156 Makefiles, and Visual Studio generators are the most well-tested however.
160 ParaView only requires a few packages in order to build in general, however
161 specific features may require additional packages to be provided to ParaView's
167 - Version 3.12 or newer, however, the latest version is always recommended
172 - Visual Studio 2015 or newer
174 Optional dependencies:
177 - At least 3.3 is required
179 - Version 5.9 or newer
181 ##### Installing CMake
183 CMake is a tool that makes cross-platform building simple. On several systems
184 it will probably be already installed or available through system package
185 management utilities. If it is not, there are precompiled binaries available on
186 [CMake's download page][cmake-download].
190 ParaView uses Qt as its GUI library. Precompiled binaries are available on
191 [Qt's website][qt-download].
193 Note that on Windows, the compiler used for building ParaView must match the
194 compiler version used to build Qt.
196 The Linux packages for Qt 5.9 use a version of protobuf that may conflict with
197 that used by ParaView. If, when running ParaView, error messages about a
198 mismatch in protobuf versions appears, moving the `libqgtk3.so` plugin out of
199 the `plugins/platformthemes` directory has been sufficient in the past.
201 #### Optional Additions
203 ##### Download And Install ffmpeg (`.avi`) movie libraries
205 When the ability to write `.avi` files is desired, and writing these files is
206 not supported by the OS, ParaView can use the ffmpeg library. This is generally
207 true for Linux. Source code for ffmpeg can be obtained from [the
212 To run ParaView in parallel, an [MPI][mpi] implementation is required. If an
213 MPI implementation that exploits special interconnect hardware is provided on
214 your system, we suggest using it for optimal performance. Otherwise, on
215 Linux/Mac, we suggest either [OpenMPI][openmpi] or [MPICH][mpich]. On Windows,
216 [Microsoft MPI][msmpi] is required.
220 In order to use scripting, [Python][python] is required (version 3.3). Python
221 is also required in order to build ParaViewWeb support.
225 Off-screen Mesa can be used as a software-renderer for running ParaView on a
226 server without hardware OpenGL acceleration. This is usually available in
227 system packages on Linux. For example, the `libosmesa6-dev` package on Debian
228 and Ubuntu. However, for older machines, building a newer version of Mesa is
229 likely necessary for bug fixes and support. Its source and build instructions
230 can be found on [its website][mesa].
232 ### Creating the Build Environment
234 #### Linux (Ubuntu/Debian)
236 * `sudo apt install` the following packages:
243 - `ninja` is a speedy replacement for `make`, highly recommended.
245 *Note*: If you are using an Ubuntu-provided compiler, there is a known issue
246 with the optional Python linking. This case is hard to auto-detect, so if
247 undefined symbol errors related to Python symbols arise, setting
248 `vtk_undefined_symbols_allowed=OFF` may resolve the errors. If it does not,
249 please file a new issue.
253 * [Visual Studio 2015 Community Edition][visual-studio]
254 * Use "x64 Native Tools Command Prompt" for the installed Visual Studio
255 version to configure with CMake and to build with ninja.
256 * Get [ninja][ninja]. Unzip the binary and put it in `PATH`.
260 In order to build, CMake requires two steps, configure and build. ParaView
261 itself does not support what are known as in-source builds, so the first step
262 is to create a build directory.
265 On Windows, there have historically been issues with long paths to the
266 build directory. These should have been addressed, but they may appear
267 again. If any are seen, please report them to [the issue
268 tracker][paraview-issues].
271 mkdir -p paraview/build
273 ccmake ../path/to/paraview/source # -GNinja may be added to use the Ninja generator
276 CMake's GUI has input entries for the build directory and the generator
277 already. Note that on Windows, the GUI must be launched from a "Native Tools
278 Command Prompt" available with Visual Studio in the start menu.
282 ParaView has a number of settings available for its build. These are categorized
283 as build options, capability option, feature options and miscellanoues options.
288 These options impact the build. These begin with the prefix `PARAVIEW_BUILD_`.
289 The common variables to modify include:
291 * `PARAVIEW_BUILD_SHARED_LIBS` (default `ON`): If set, shared libraries will
292 be built. This is usually what is wanted.
294 Less common, but variables which may be of interest to some:
296 * `PARAVIEW_BUILD_EDITION` (default `CANONICAL`): Choose which features to
297 enable in this build. This is useful to generate ParaView builds with
298 limited features. More on this later.
299 * `PARAVIEW_BUILD_EXAMPLES` (default `OFF`): If set, ParaView's example code
300 will be added as tests to the ParaView test suite.
301 * `PARAVIEW_BUILD_DEVELOPER_DOCUMENTATION` (default `OFF`): If set, the HTML
302 documentation for ParaView's C++, Python, and proxies will be generated.
303 * `PARAVIEW_BUILD_TESTING` (default `OFF`): Whether to build tests or not.
304 Valid values are `OFF` (no testing), `WANT` (enable tests as possible), and
305 `ON` (enable all tests; may error out if features otherwise disabled are
306 required by test code).
307 * `PARAVIEW_BUILD_VTK_TESTING` (default `OFF`): Whether to build tests for the
308 VTK codebase built by ParaView. Valid values are same as
309 `PARAVIEW_BUILD_TESTING`.
311 More advanced build options are:
313 * `PARAVIEW_BUILD_ALL_MODULES` (default `OFF`): If set, ParaView will enable
314 all modules not disabled by other features.
315 * `PARAVIEW_BUILD_LEGACY_REMOVE` (default `OFF`): Remove legacy / deprecated
317 * `PARAVIEW_BUILD_LEGACY_SILENT` (default `OFF`): Silence all legacy
318 / deprecated code messages.
319 * `PARAVIEW_BUILD_WITH_EXTERNAL` (default `OFF`): When set to `ON`, the build
320 will try to use external copies of all included third party libraries unless
321 explicitly overridden.
322 * `PARAVIEW_BUILD_WITH_KITS` (default `OFF`): Compile ParaView into a smaller
323 set of libraries. Can be useful on platforms where ParaView takes a long
324 time to launch due to expensive disk access.
326 #### Capability settings
328 These settings control capabitities of the build. These begin with the prefix
329 `PARAVIEW_USE_`. The common variables to modify include:
331 * `PARAVIEW_USE_QT` (default `ON`): Builds the `paraview` GUI application.
332 * `PARAVIEW_USE_MPI` (default `OFF`): Whether MPI support will be available
334 * `PARAVIEW_USE_PYTHON` (default `OFF`): Whether Python
335 support will be available or not.
337 Less common, but potentially useful variables are:
339 * `PARAVIEW_USE_VTKM` (default `ON`): Whether VTK-m based filters are enabled.
340 * `PARAVIEW_USE_FORTRAN` (default `ON` if Fortran compiler found): Enable
341 Fortran support for Catalyst libraries.
343 #### Feature settings
345 These settings control optional features. These begin with the prefix
346 `PARAVIEW_ENABLE_`. The common variables to modify include:
348 * `PARAVIEW_ENABLE_RAYTRACING` (default `OFF`): Enable ray-tracing support
349 with OSPray and/or OptiX. Requires appropriate external libraries.
350 * `PARAVIEW_ENABLE_WEB` (default `OFF`; requires `PARAVIEW_USE_PYTHON`):
351 Whether ParaViewWeb support will be available or not.
353 More advanced / less common options include:
355 * `PARAVIEW_ENABLE_VISITBRIDGE` (default `OFF`): Enable support for VisIt
357 * `PARAVIEW_ENABLE_NVPIPE` (default `OFF`): Use [nvpipe][nvpipe] image
358 compression when communicating the GPU. Requires CUDA and an NVIDIA GPU.
359 * `PARAVIEW_ENABLE_GDAL` (default `OFF`): Enable support for reading GDAL
361 * `PARAVIEW_ENABLE_LAS` (default `OFF`): Enable support for reading LAS
363 * `PARAVIEW_ENABLE_OPENTURNS` (default `OFF`): Enable support for reading
365 * `PARAVIEW_ENABLE_PDAL` (default `OFF`): Enable support for reading PDAL
367 * `PARAVIEW_ENABLE_MOTIONFX` (default `OFF`): Enable support for reading
369 * `PARAVIEW_ENABLE_MOMENTINVARIANTS` (default `OFF`): Enable
370 MomentInvariants filters.
371 * `PARAVIEW_ENABLE_LOOKINGGLASS` (default `OFF`): Enable LookingGlass display.
372 * `PARAVIEW_ENABLE_XDMF2` (default `OFF`): Enable support for reading Xdmf2
374 * `PARAVIEW_ENABLE_XDMF3` (default `OFF`): Enable support for reading Xdmf3
376 * `PARAVIEW_ENABLE_FFMPEG` (default `OFF`; not available on Windows): Enable
378 * `PARAVIEW_ENABLE_COSMOTOOLS` (default `OFF`; requires `PARAVIEW_USE_MPI`
379 and not available on Windows): Enable support for CosmoTools which includes
380 GenericIO readers and writers as well as some point cloud algorithms.
385 ParaView build includes several plugins. These can be enabled / disabled using the
388 * `PARAVIEW_PLUGINS_DEFAULT` (default `ON`): Pass this flag to the command
389 line using `-DPARAVIEW_PLUGINS_DEFAULT=OFF` before the first cmake run to
390 disable all plugins by default. Note this has no impact after the first
391 cmake configure and hence must be passed on the command line itself.
392 * `PARAVIEW_PLUGIN_ENABLE_<name>` (default varies): Whether to enable a
394 * `PARAVIEW_PLUGIN_AUTOLOAD_<name>` (default `OFF`): Whether to autoload a
395 plugin at startup or not. Note that this affects all clients linking to
396 ParaView's plugin target.
398 #### Miscellaneous settings
399 ParaView uses VTK's module system to control its build. This infrastructure
400 provides a number of variables to control modules which are not otherwise
401 controlled by the other options provided.
403 * `VTK_MODULE_USE_EXTERNAL_<name>` (default depends on
404 `PARAVIEW_BUILD_WITH_EXTERNAL`): Use an external source for the named third-party
405 module rather than the copy contained within the ParaView source tree.
406 * `VTK_MODULE_ENABLE_<name>` (default `DEFAULT`): Change the build settings
407 for the named module. Valid values are those for the module system's build
408 settings (see below).
409 * `VTK_GROUP_ENABLE_<name>` (default `DEFAULT`): Change the default build
410 settings for modules belonging to the named group. Valid values are those
411 for the module system's build settings (see below).
413 For variables which use the module system's build settings, the valid values are as follows:
415 * `YES`: Require the module to be built.
416 * `WANT`: Build the module if possible.
417 * `DEFAULT`: Use the settings by the module's groups and
418 `PARAVIEW_BUILD_ALL_MODULES`.
419 * `DONT_WANT`: Don't build the module unless required as a dependency.
420 * `NO`: Do not build the module.
422 If any `YES` module requires a `NO` module, an error is raised.
424 More advanced options:
426 * `PARAVIEW_INITIALIZE_MPI_ON_CLIENT` (default `ON`; requires
427 `PARAVIEW_USE_MPI`): Initialize MPI on client processes by default.
428 * `PARAVIEW_USE_QTHELP` (default `ON`; requires
429 `PARAVIEW_USE_QT`): Use Qt's help infrastructure for runtime
431 * `PARAVIEW_VERSIONED_INSTALL` (default `ON`): Whether to add version numbers
432 to ParaView's include and plugin directories in the install tree.
433 * `PARAVIEW_CUSTOM_LIBRARY_SUFFIX` (default depends on
434 `PARAVIEW_VERSIONED_INSTALL`): The custom suffix for libraries built by
435 ParaView. Defaults to either an empty string or `pvX.Y` where `X` and `Y`
436 are ParaView's major and minor version components, respectively.
437 * `PARAVIEW_INSTALL_DEVELOPMENT_FILES` (default `ON`): If set, ParaView will
438 install its headers, CMake API, etc. into its install tree for use.
439 * `PARAVIEW_RELOCATABLE_INSTALL` (default `ON`): If set, the install tree
440 will be relocatable to another path or machine. External dependencies
441 needed by ParaView which are in non-standard locations may need manual
442 settings in ParaView-using projects (those which share an install prefix
443 with ParaView should be OK though). If unset, the install tree will include
444 hints for the location of its dependencies which may include
445 build-machine-specific paths in the install tree.
446 * `PARAVIEW_SERIAL_TESTS_USE_MPIEXEC` (default `OFF`): Used on HPC to run
447 serial tests on compute nodes. If set, it prefixes serial tests with
448 "${MPIEXEC_EXECUTABLE}" "${MPIEXEC_NUMPROC_FLAG}" "1" ${MPIEXEC_PREFLAGS}
451 These variables should be documented once they're effective again.
453 * `PARAVIEW_USE_EXTERNAL_VTK` (default `OFF`): Use an externally provided
454 VTK. Note that ParaView has fairly narrow requirements for the VTK it can
455 use, so only very recent versions are likely to work.
459 A typical ParaView build includes several modules and dependencies. While these
460 are necessary for a fully functional application, there are cases (e.g. in situ
461 use-cases) where a build with limited set of features is adequate. ParaView build supports
462 this using the `PARAVIEW_BUILD_EDITION` setting. Supported values for this setting are:
464 * `CORE`: Build modules necessary for core ParaView functionality.
465 This does not include rendering.
466 * `RENDERING`: Build modules necessary for supporting rendering including views
467 and representations. This includes everything in `CORE`.
468 * `CATALYST`: Build all modules necessary for in situ use cases without
469 rendering and optional components like NetCDF- and HDF5-based readers and
471 * `CATALYST_RENDERING`: Same as `CATALYST` but with rendering supported added.
472 * `CANONICAL` (default): Build modules necessary for standard ParaView build.
475 ### Building documentation
477 The following targets are used to build documentation for ParaView:
479 * `ParaViewDoxygenDoc` - build the doxygen documentation from ParaView's C++ source files.
480 * `ParaViewPythonDoc` - build the documentation from ParaView's Python source files.
481 * `ParaViewDoc-TGZ` - build a gzipped tarball of ParaView documentation.
485 [Spack][spack] is a package manager for supercomputers, Linux and macOS. ParaView is one of
486 the packages available in Spack. To install ParaView from spack, you can use:
489 spack install paraview
492 Please refer to [Spack documentation][spack-docs] for ways of customizing the install,
493 including choosing the version and/or variant to build. Based on the version chosen,
494 spack will download appropriate ParaView source and build it.
496 To make it easier to build ParaView using spack from an existing source checkout, we have included
497 relevant spack `package.yaml` files within the ParaView codebase itself. This
498 also makes it easier to keep the spack package up-to-date with any changes to
499 the ParaView buildsystem. With every release (and as frequently as required), we
500 will push the changes to the ParaView paraview.yaml file upstream to the
501 official spack repository.
503 To build your existing source checkout of ParaView using Spack, here are the
507 # assuming you've installed spack as documented in spack docs
508 # and activate the spack environment appropriately
510 # add custom paraview/package.yaml
511 > spack repo add $PARAVIEW_SOURCE_DIR/Utilities/spack/repo
513 # use info to confirm that the paraview package is available
514 # only one version should be available
515 > spack info paraview
517 # install similar to any other spack package
518 # e.g. following command installs osmesa-capable ParaView
521 > spack install paraview+osmesa^mesa~glx^mpich
524 [cmake-download]: https://cmake.org/download
525 [cmake]: https://cmake.org
526 [ffmpeg]: https://ffmpeg.org
527 [git]: https://git-scm.org
528 [gitforwindows]: https://gitforwindows.org/
529 [mesa]: https://www.mesa3d.org
530 [mpi]: https://www.mcs.anl.gov/research/projects/mpi
531 [mpich]: https://www.mpich.org
532 [msmpi]: https://docs.microsoft.com/en-us/message-passing-interface/microsoft-mpi
533 [ninja]: https://github.com/ninja-build/ninja/releases
534 [nvpipe]: https://github.com/NVIDIA/NvPipe
535 [openmpi]: https://www.open-mpi.org
536 [paraview-issues]: https://gitlab.kitware.com/paraview/paraview/-/issues
537 [python]: https://python.org
538 [pythonwindows]: https://www.python.org/downloads/windows/
539 [qt-download]: https://download.qt.io/official_releases/qt
541 [qt-download-5.12.3]: https://download.qt.io/archive/qt/5.12/5.12.3/
542 [tbb]: https://github.com/intel/tbb/releases
543 [visual-studio]: https://visualstudio.microsoft.com/vs/older-downloads
544 [spack]: https://spack.io/
545 [spack-docs]: https://spack.readthedocs.io/en/latest/
