1 # Install script for directory: /home/paraview/VTK/Wrapping/Tools 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47 "/home/paraview/VTK/Wrapping/Tools/vtkParse.h" 48 "/home/paraview/VTK/Wrapping/Tools/vtkParseData.h" 49 "/home/paraview/VTK/Wrapping/Tools/vtkParseExtras.h" 50 "/home/paraview/VTK/Wrapping/Tools/vtkParseHierarchy.h" 51 "/home/paraview/VTK/Wrapping/Tools/vtkParseMain.h" 52 "/home/paraview/VTK/Wrapping/Tools/vtkParseMangle.h" 53 "/home/paraview/VTK/Wrapping/Tools/vtkParseMerge.h" 54 "/home/paraview/VTK/Wrapping/Tools/vtkParsePreprocess.h" 55 "/home/paraview/VTK/Wrapping/Tools/vtkParseString.h" 56 "/home/paraview/VTK/Wrapping/Tools/vtkParseType.h" 57 "/home/paraview/VTK/Wrapping/Tools/vtkWrap.h" 58 "/home/paraview/build/VTK/Wrapping/Tools/vtkWrappingToolsModule.h" 62 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 64 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.9.so.5.9
" 65 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.9.so.1
" 67 if(EXISTS "${file}
" AND 68 NOT IS_SYMLINK "${file}
") 74 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 75 "/home/paraview/build/lib64/libvtkWrappingTools-pv5.9.so.5.9
" 76 "/home/paraview/build/lib64/libvtkWrappingTools-pv5.9.so.1
" 79 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.9.so.5.9
" 80 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.9.so.1
" 82 if(EXISTS "${file}
" AND 83 NOT IS_SYMLINK "${file}
") 88 if(CMAKE_INSTALL_DO_STRIP) 89 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 95 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 96 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.9.so
" AND 97 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.9.so
") 99 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.9.so
" 102 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkWrappingTools-pv5.9.so
") 103 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.9.so
" AND 104 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.9.so
") 106 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.9.so
" 108 NEW_RPATH "\$ORIGIN
") 109 if(CMAKE_INSTALL_DO_STRIP) 110 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.9.so
") 115 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 116 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.9
" AND 117 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.9
") 119 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.9
" 120 RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 122 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/home/paraview/build/bin/vtkWrapHierarchy-pv5.9
") 123 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.9
" AND 124 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.9
") 126 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.9
" 127 OLD_RPATH "\$ORIGIN/../lib64::::::::
" 128 NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 129 if(CMAKE_INSTALL_DO_STRIP) 130 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.9
") 135 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 136 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.9
" AND 137 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.9
") 139 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.9
" 140 RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 142 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/home/paraview/build/bin/vtkWrapPython-pv5.9
") 143 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.9
" AND 144 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.9
") 146 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.9
" 147 OLD_RPATH "\$ORIGIN/../lib64::::::::
" 148 NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 149 if(CMAKE_INSTALL_DO_STRIP) 150 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.9
") 155 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 156 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.9
" AND 157 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.9
") 159 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.9
" 160 RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 162 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/home/paraview/build/bin/vtkWrapPythonInit-pv5.9
") 163 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.9
" AND 164 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.9
") 166 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.9
" 167 OLD_RPATH "::::::::::::::::::::::::
" 168 NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 169 if(CMAKE_INSTALL_DO_STRIP) 170 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.9
") 175 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 176 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.9
" AND 177 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.9
") 179 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.9
" 180 RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 182 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/home/paraview/build/bin/vtkParseJava-pv5.9
") 183 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.9
" AND 184 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.9
") 186 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.9
" 187 OLD_RPATH "\$ORIGIN/../lib64::::::::
" 188 NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 189 if(CMAKE_INSTALL_DO_STRIP) 190 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.9
") 195 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 196 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.9
" AND 197 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.9
") 199 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.9
" 200 RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 202 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/home/paraview/build/bin/vtkWrapJava-pv5.9
") 203 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.9
" AND 204 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.9
") 206 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.9
" 207 OLD_RPATH "\$ORIGIN/../lib64::::::::
" 208 NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64
") 209 if(CMAKE_INSTALL_DO_STRIP) 210 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.9
