1 # Install script for directory: /home/paraview/VTK/Wrapping/PythonCore
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/VTK/Wrapping/PythonCore/PyVTKEnum.h"
48  "/home/paraview/VTK/Wrapping/PythonCore/PyVTKMethodDescriptor.h"
49  "/home/paraview/VTK/Wrapping/PythonCore/PyVTKNamespace.h"
50  "/home/paraview/VTK/Wrapping/PythonCore/PyVTKObject.h"
51  "/home/paraview/VTK/Wrapping/PythonCore/PyVTKReference.h"
52  "/home/paraview/VTK/Wrapping/PythonCore/PyVTKSpecialObject.h"
53  "/home/paraview/VTK/Wrapping/PythonCore/PyVTKTemplate.h"
54  "/home/paraview/VTK/Wrapping/PythonCore/vtkPythonCompatibility.h"
55  "/home/paraview/VTK/Wrapping/PythonCore/vtkPythonArgs.h"
56  "/home/paraview/VTK/Wrapping/PythonCore/vtkPythonCommand.h"
57  "/home/paraview/VTK/Wrapping/PythonCore/vtkPythonOverload.h"
58  "/home/paraview/VTK/Wrapping/PythonCore/vtkPythonUtil.h"
59  "/home/paraview/VTK/Wrapping/PythonCore/vtkSmartPyObject.h"
60  "/home/paraview/build/VTK/Wrapping/PythonCore/vtkWrappingPythonCoreModule.h"
61  )
62 endif()
63
64 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingPythonCore3.9-pv5.9.so.5.9"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingPythonCore3.9-pv5.9.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHECK
72  FILE "${file}"
73  RPATH "\$ORIGIN")
74  endif()
75  endforeach()
76  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
77  "/home/paraview/build/lib64/libvtkWrappingPythonCore3.9-pv5.9.so.5.9"
78  "/home/paraview/build/lib64/libvtkWrappingPythonCore3.9-pv5.9.so.1"
79  )
80  foreach(file
81  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingPythonCore3.9-pv5.9.so.5.9"
82  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingPythonCore3.9-pv5.9.so.1"
83  )
84  if(EXISTS "${file}" AND
85  NOT IS_SYMLINK "${file}")
86  file(RPATH_CHANGE
87  FILE "${file}"
88  OLD_RPATH "/home/paraview/build/lib64:"
89  NEW_RPATH "\$ORIGIN")
90  if(CMAKE_INSTALL_DO_STRIP)
91  execute_process(COMMAND "/usr/bin/strip" "${file}")
92  endif()
93  endif()
94  endforeach()
95 endif()
96
97 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
98  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingPythonCore3.9-pv5.9.so" AND
99  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingPythonCore3.9-pv5.9.so")
100  file(RPATH_CHECK
101  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingPythonCore3.9-pv5.9.so"
102  RPATH "\$ORIGIN")
103  endif()
104  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkWrappingPythonCore3.9-pv5.9.so")
105  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingPythonCore3.9-pv5.9.so" AND
106  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingPythonCore3.9-pv5.9.so")
107  file(RPATH_CHANGE
108  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingPythonCore3.9-pv5.9.so"
109  OLD_RPATH "/home/paraview/build/lib64:"
110  NEW_RPATH "\$ORIGIN")
111  if(CMAKE_INSTALL_DO_STRIP)
112  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingPythonCore3.9-pv5.9.so")
113  endif()
114  endif()
115 endif()
116
