1 # Install script for directory: /home/paraview/VTK/Utilities/Python
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES
47  "/home/paraview/VTK/Utilities/Python/vtkPython.h"
48  "/home/paraview/build/VTK/Utilities/Python/vtkPythonConfigure.h"
49  )
50 endif()
51
