1 # Install script for directory: /home/paraview/VTK/Utilities/MetaIO/vtkmetaio
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9/vtkmetaio" TYPE FILE FILES
47  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/localMetaConfiguration.h"
48  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaArray.h"
49  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaArrow.h"
50  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaBlob.h"
51  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaCommand.h"
52  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaContour.h"
53  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaDTITube.h"
54  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaEllipse.h"
55  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaEvent.h"
56  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaFEMObject.h"
57  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaForm.h"
58  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaGaussian.h"
59  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaGroup.h"
60  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaImage.h"
61  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaImageTypes.h"
62  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaImageUtils.h"
63  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaITKUtils.h"
64  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaLandmark.h"
65  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaLine.h"
66  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaMesh.h"
67  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaObject.h"
68  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaOutput.h"
69  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaScene.h"
70  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaSurface.h"
71  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaTransform.h"
72  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaTubeGraph.h"
73  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaTube.h"
74  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaTypes.h"
75  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaUtils.h"
76  "/home/paraview/VTK/Utilities/MetaIO/vtkmetaio/metaVesselTube.h"
77  "/home/paraview/build/VTK/Utilities/MetaIO/vtkmetaio/metaIOConfig.h"
78  )
79 endif()
80
81 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
82  foreach(file
83  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv5.9.so.5.9"
84  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv5.9.so.1"
85  )
86  if(EXISTS "${file}" AND
87  NOT IS_SYMLINK "${file}")
88  file(RPATH_CHECK
89  FILE "${file}"
90  RPATH "\$ORIGIN")
91  endif()
92  endforeach()
93  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
94  "/home/paraview/build/lib64/libvtkmetaio-pv5.9.so.5.9"
95  "/home/paraview/build/lib64/libvtkmetaio-pv5.9.so.1"
96  )
97  foreach(file
98  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv5.9.so.5.9"
99  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv5.9.so.1"
100  )
101  if(EXISTS "${file}" AND
102  NOT IS_SYMLINK "${file}")
103  file(RPATH_CHANGE
104  FILE "${file}"
105  OLD_RPATH "/home/paraview/build/lib64:"
106  NEW_RPATH "\$ORIGIN")
107  if(CMAKE_INSTALL_DO_STRIP)
108  execute_process(COMMAND "/usr/bin/strip" "${file}")
109  endif()
110  endif()
111  endforeach()
112 endif()
113
114 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
115  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv5.9.so" AND
116  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv5.9.so")
117  file(RPATH_CHECK
118  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv5.9.so"
119  RPATH "\$ORIGIN")
120  endif()
121  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/home/paraview/build/lib64/libvtkmetaio-pv5.9.so")
122  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv5.9.so" AND
123  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv5.9.so")
124  file(RPATH_CHANGE
125  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv5.9.so"
126  OLD_RPATH "/home/paraview/build/lib64:"
127  NEW_RPATH "\$ORIGIN")
128  if(CMAKE_INSTALL_DO_STRIP)
129  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkmetaio-pv5.9.so")
130  endif()
131  endif()
132 endif()
133
