1 # Install script for directory: /home/paraview/VTK/Utilities/MPI
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9" TYPE FILE FILES "/home/paraview/VTK/Utilities/MPI/vtk_mpi.h")
47 endif()
48
