1 # Install script for directory: /home/paraview/VTK/Utilities/KWIML/vtkkwiml
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9/vtkkwiml" TYPE FILE FILES
47  "/home/paraview/VTK/Utilities/KWIML/vtkkwiml/include/kwiml/abi.h"
48  "/home/paraview/VTK/Utilities/KWIML/vtkkwiml/include/kwiml/int.h"
49  )
50 endif()
51
