1 # Install script for directory: /home/paraview/VTK/ThirdParty/utf8/vtkutf8 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.9/vtkutf8" TYPE FILE FILES
"/home/paraview/VTK/ThirdParty/utf8/vtkutf8/utf8.h")
49 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 50 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.9/vtkutf8/utf8
" TYPE FILE FILES 51 "/home/paraview/VTK/ThirdParty/utf8/vtkutf8/utf8/checked.h
" 52 "/home/paraview/VTK/ThirdParty/utf8/vtkutf8/utf8/core.h
" 53 "/home/paraview/VTK/ThirdParty/utf8/vtkutf8/utf8/unchecked.h
