1 # Install script for directory: /home/paraview/VTK/ThirdParty/tiff/vtktiff
47  include("/home/paraview/build/VTK/ThirdParty/tiff/vtktiff/port/cmake_install.cmake")
48 endif()
49
50 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
51  # Include the install script for the subdirectory.
52  include("/home/paraview/build/VTK/ThirdParty/tiff/vtktiff/libtiff/cmake_install.cmake")
53 endif()
54
